Originally posted by Jim Gilbert Thanks for the input.
@Jeverrettfine I am always looking for the best picture from the start. I spent a lot of time in my darkroom and have always found that although you can tweak some great results from the enlarger it is always better to start off with an image that is as close to where to where you want from the beginning.
@Nomadkng reading up on ETTR. Histograms are a whole new world for me.
---------- Post added 01-29-15 at 10:26 AM ----------
Thanks @Sagitta. I have read up on bracketing on the K50 and love that you can customize what you want to expose up or down. How much do you usually bracket up and down?
I am looking at post production software. I have to find something that is useful and fits my budget.
I usually just go with 'normal' then +1 or +2 (usually +2) up and down with the K-30 since it limits brackets to 3 shots. I'm ordering a K-3 to replace the 30 though, and I believe that that will allow for more exposures when bracketing, so will probably change up how I go about doing so.
I also don't know if you mentioned it or not, but do you shoot in RAW or JPG? With sunset/sunrise/generally dark shots RAW tends to be a much better option since you can yank details from the murk much more easily than you can from a JPG, as more detail is stored in the RAW files to play with.
While you can shoot them in JPG, the ability to go in and much with them after the fact gets extremely limited with a JPG file.
