It's an intriguing shot, and I appreciate your work. If you don't mind my trying to help....
I copied your low resolution JPEG into Photoshop to offer two different interpretations of the same scene. The first keeps your wide view but crops away some relatively empty negative space and also lightens the man and darkens the overly lit arch. The second crops far into the photo to emphasize both the arch and the man beside it, again lightening and darkening to minimize the overcontrast of the original and to bring out the man more.
If I were advising you, and you could set up and shoot the scene again, here would be my suggestions:
1) identify your subject better, because the original is confusing your audience. Is it the floating man (probably), the arches, the effect of the spiritually charged space on the man?
2) fill your frame with your subject. If it is to emphasize the man, show him larger in the frame.
3) control contrast better. The man is too dark compared to other parts of the scence.
4) add some punch to the scene (say, with post-processing or with HDR techniques). The tones are relatively flat.
5) shoot in RAW or at least high-resolution JPEGS. RAW will give you more latitude to play with the image in post-processing and will allow you to crop without artifacts such as the ones now visible in my versions of your photo. (You may have done this already, having posted only a low-res image in order to meet the PF.com limits. If so, you can crop in many ways and post-process in many ways to improve this photo.)
6) Assuming your main subject is the man, ensure that he is in perfect focus. Even if you have to sacrifice some depth of field with a larger f-stop to ensure a fast enough shutter speed to freeze his motion. Alternatively, use high ISO, keep your shutter fast, and still have a small enough aperture to get sufficient depth of field.
