you can download my photoshop action here, its fairly simple.
http://davecsmith.com/Dave.atn
open your file in photoshop and run the action.
It will create 2 new layers one named color, and one named texture.
typically I hide the texture layer and work on the color first.
In general you can use the lasso select tool with a feather value of 8-16 (play with this a bit, it depends some on the size of your image) and pick large areas of like colored skin and Gaussian blur them.
If there are particularly bad blemishes you can clone or heal them out first.
Once that is done un-hide the texture layer and and use the clone tool to clone out bumps/pimples etc from the texture.
This will leave you with some skin texture pores / etc but the appearance of a very clean face.
---------- Post added 03-15-15 at 03:38 PM ----------
Originally posted by dave1479 you can download my photoshop action here, its fairly simple.
Using this method you can also recover blown out areas if they are particularly bad you can add an empty layer between the color and texture layer, then use the color picker tool to get the color of some nearby skin.
then using a soft brush paint over the blown out area...you could also do this directly on the color layer, but I like to try to keep things non-destructive and using the extra layer makes it easier to revert if you mess it up.
once that is done play with the fill and opacity of the painted layer until it looks natural. If it is particularly bad you may also have to clone some skin texture from a nearby area over the blown out spot using the texture layer.
