Originally posted by Winder It's a hard shot with her in white against a dark back ground. I think the light might have been too small/hard. Her left shoulder has a glow from the light/high contrast and there is artifact running down her right side all the way to the box she is sitting on. Did you use a brush to smooth out the background? Her hair also show signs of brushing and smoothing. What size was your light source and how far was it from the subject? Might try a light behind the subject or a background light. It's hard to get the subject separation with a 43mm lens at F/8.
For a larger print the glow on the shoulder and artifact would definitely show up.
yes, the artifact is very distracting.
The backdrop is painted foam core, so I used the "skin softening" feature of NIK software to blur it out. Then used a layer mask to try and only blur the backdrop. I don't remember doing it...but looking at it I figure I probably went in with a paintbrush and painted in some of the grey too, probably that's why her hairs a bit messed up. Or maybe the crease between the two boards when I was cloning.
As for lighting, we got a 100cm Deepthroat Octabox on camera left with the bulb just above her head and the box angling down. I have another 40cm softbox directly above her.
