Hi
I agree with
wildman.
Its a terrific little picture but it would need a bit more shadow detail. Mind you this is not easily accomplished with the bright window. Exposure is tricky, either you blow out the window (no, not the window, the image outside
) and get better exposure of the books on the shelf or the other way around.
Image stacking is the way to go here. But there is another way to do something about it at least to a certain level of satisfaction. You need software which will allow you to target certain areas of the image for manipulation. The best file format to do this with is of course RAW which will have more information to work with and you will be amazed how much detail shadow areas contain waiting to be rescued.
Here is an example. I use a nifty little program called Nik Viveza which will allow you to target any area in the image for manipulation. But don't forget I have worked here on a small 8bit JPG, so it is not optimal.
Regards
