Originally posted by Bruce Clark Without getting bogged down in semantics, a true Macro lens will be a fixed focal length, 50, 100 or 200mm and give a magnification of at least 1:1 at its minimum focusing distance.
I'm not sure I would completely agree with this. Yes, zoom lenses labelled as "macro" are usually not on the same level as fixed focal length. Some barely allow any more magnification than a regular lens. But remember that not long ago many macro lenses only went down to 1:2 magnification. Even modern
Zeiss macro lenses only go to 1:2. And OP's lens also goes to 1:2, at least according to the
specifications. I also think it is generally accepted that 1:2 is where the "macro" range begins, and 1:1 is true macro. If the lens goes further beyond that, its enlargement. But you are right, a dedicated fixed focal length macro lens will give even better clarity, magnification. I'm just saying that the lens OP used does allow quite a bit of magnification and from the photo above seems reasonably sharp in the area, where focus is achieved.
Now back to the photo. Good aperture for DoF. Was this taken with a tripod? Because handholding at that magnification and focal length can be quite difficult and 1/200 shutter speed might not be fast enough. But the photo doesn't seem to be smudged, so thats not a problem. In my hands, I would need a little faster shutter speed (and thus higher ISO) to guarantee sharpness at that magnification, even with SR enabled.
The fuzzy, fluffy flower looks nice, it is well-exposed. I like taking photos of flowers without the typical petals and blooms, so I appreciate it. But some viewers will want either a subject (like a bug climbing on the flowers) or even more magnification (which you can get from this photo by cropping, if you haven't already)
Anyway, nice one, I like it, you are on the right path
Of course, with macro, there is always more to do - buying lights, tripod, extension tubes or bellows, reversing lenses, buying more lenses, more lights..
