Originally posted by BrianR My first thought is the haze is the out of focus fence and not glare or flare etc.. If it is the fence itself, you want to
- be as close to the fence as possible (this can mean removing the hood, but be careful not to touch the front element with the fence)
- use the widest aperture possible
- do your best to shoot through a hole in the fence
- ideally shade the part of the fence you're shooting through from the sunlight
How big were the holes in the fence? Big enough that your lens had an unobstructed view through them?
Yes, I was shooting through the fence hole, that the lens hood fit right into, I might have touched it or even slightly rested the hood on it in fact.
I was literally that close, let me show you guys another pic I took from the same spot, this is one shot before the pic above. same spot, same time, just one shot before literally, I just moved the angle up slightly if I remember correctly, and looking at the pictures right.(I honestly thought there was some way to "fix" the above image with photoshop.)
