Originally posted by DW58
Hey BigMacCam.
Just guessing about the 4". I got as close as I could. How embarrassing it would be if I was too close. But I thought the 5.5" was from subject to sensor not subject to front element of lens.
Took several shots at different apertures but used auto focus. Had remote set up to change focus. Used Select AF and changed focus points through viewfinder 3 times. Lens moved slightly and I heard the beep before mirror lock-up and exposure each time.
Looking back I should have tried manual focus. Have not tried live view with focus peaking yet. But plan to now. No filter used.
Minor sharpening in Silkypix. Have had my K-50 for two months and started shooting RAW two weeks ago. Haven't quite got a handle on PP yet. Mostly computer illiterate so it's been an adventure. Will just keep plugging away though.
Rain was moving in and didn't have time to try many different set ups.
I have a lot to learn and I think I'm getting a bit impatient. Want everything to come together NOW.
Thanks for all your help Mike. I appreciate it.
My pleasure, Eugene. I know all about impatience - I've been perfecting it since childhood
Yes, you're correct - minimum focus distance
is from subject to sensor... Worth checking next time that you are far enough back. I've had situations where I've tried to focus a lens while too close to the subject, and have still got focus confirmation back, but the focus has been poor.
Live view uses contrast detect auto-focus which is more accurate than the phase detect used in viewfinder mode. Even so, depending on the exact part of the subject you're aiming at, with a complex focus area consisting of leaves / stalks, this can prove a challenge for auto-focus, and live view with focus peaking will be a great additional test to carry out.
Best of luck and let us know how you get on?
