Originally posted by PoppaTom This picture represents a number of firsts for me:
- My first attempt at stacking pictures to remove tourists/other photographers.
- my first use of Silver Efex Pro
- my first posting of an image
- Have I over sharpened?
- Is the contrast too much?
- Does it look over processed?
- Would the image support darker skies?
The picture is of the lighthouse at Peggys Cove, Nova Scotia.
thanks in advance
G'Day mate, some feedback as requested:
- My first attempt at stacking pictures to remove tourists/other photographers. You did this well as I had no idea that you needed to remove tourists etc
- my first use of Silver Efex Pro Looks good to me
- my first posting of an image Cool, and there'll be more to come I hope.
- Have I over sharpened? The image is a bit small so it's hard to tell. I can't see any haloing around edges or heavy black/white lines so I'm guessing not. Check the 'blue' parts of the sky for noise. If you see noise there it might be oversharpened or needing more masking slider in the detail panel. Preferably you sharpen on a mask so you can select what you sharpen instead of doing it globally.
- Is the contrast too much? Nope
- Does it look over processed? Nope, but I agree with Special K about the leaning Lighthouse, the correction for this can be found in the 'Transform' panel in LR6.
- Would the image support darker skies? You could do this but it would likely be at the expense of looking natural. A good way of checking that is to use the blue and aqua channels only in LR6. Darken the aqua then the blue going to the extreme to start with and then drawing it back to find the correct balance.
The picture is of the lighthouse at Peggys Cove, Nova Scotia. A place I'd love to visit.
Tas
Edit: I forgot to mention that I keep being drawn to the rock in the left bottom corner of the frame. I don't think it contributes to the image but if you're going back there to a similar composition IMHO I'd leave that out.
