10-12-2016, 07:04 AM - 2 Likes   #1
adsouza's Avatar
Looking at Fall
Lens: 16-45mm F4 Camera: *istDS2 Photo Location: Toronto ISO: 200 Shutter Speed: 1/125s Aperture: F6.7
Developing my photography so I am trying to improve and would gladly welcome your C&C.
PENTAX *ist DS2  Photo
10-12-2016, 08:32 AM   #2
I really like this. It's a well worn idea but you have used it well.
10-12-2016, 08:40 AM   #3
adsouza's Avatar
QuoteOriginally posted by From1980 Quote
Thank you for your comment it is so much appreciated. I am new at it but attempting to improve my skills.
10-12-2016, 10:20 AM   #4
Otis Memorial Pentaxian
clackers's Avatar
It's not just the framing I like, but the colour vs monochrome balance, too.
10-12-2016, 11:13 AM - 1 Like   #5
Tako Kichi's Avatar
I like the colours vs monochrome look too, the only thing that I find a little jarring is the small patch of leaves in the upper right corner. It would have been nicer IMHO if the wall had continued to fill the corner but maybe the location did not allow for a re-position prior to taking the shot. I'm not sure if a tighter crop on the right side to lose the leaves would work as it would throw out the balance on the rest of the frame. You can't really crop more from the top as you would lose the top of the window frame too. A square or vertical (portrait) crop might work though, especially if you have more room on the original (I'm not sure if the example shown is cropped or not).
10-13-2016, 08:29 AM   #6
adsouza's Avatar
QuoteOriginally posted by Tako Kichi Quote
Thank you Larry much appreciated if memory serves me right I tried my best to keep the right top out while taking the photo as well as in post but it could not happen. Next time I will keep a critical eye in the viewfinder to eliminate such distractions. Thanks once again.
---------- Post added 10-13-16 at 11:31 AM ----------
Thank you for favourable comment. Much appreciated.
10-13-2016, 09:42 AM   #7
Tako Kichi's Avatar
QuoteOriginally posted by adsouza Quote
I started shooting with SLRs in the film days (1979) when it was the done thing to compose the finished image in the view finder because you couldn't crop the shot afterwards (unless you had access to a darkroom or you sliced the print into a non-standard size). Some printing outlets would allow you to specify a specific crop but that was usually at an additional cost.
With modern post-processing software the photographer has many more options available and the need to compose in the view finder is now far less critical. If the shot above is not cropped (i.e. it is what you saw in the view finder) then you may have benefited by zooming out a little bit (or stepping backwards if using a prime) so that you had more space around what you envisaged as the finished image. You would then have had more options for cropping and a better chance of getting the 'keeper' you wanted.
Old habits are hard to break and I still try to compose in the view finder but if I find I'm not able to get the shot I want I will look at leaving space around the subject so that I can crop in PP.
10-14-2016, 10:37 AM   #8
adsouza's Avatar
Thank you and much appreciated, I can use all the help to improve.
10-15-2016, 06:54 AM   #9
smf
smf's Avatar
I join in the praise, and I applaud the first post byTako Kichi.
I like a cropped vesion (cropped a bit from the right).
Adsouza, I hope to see more of your images.
Best wishes.
10-15-2016, 09:02 AM   #10
adsouza's Avatar
QuoteOriginally posted by smf Quote
I join in the praise, and I applaud the first post Btu Tako Kichi.
Best wishes.
Thank you and I definitely will post more images.
10-31-2016, 04:24 PM   #11
slip's Avatar
you have an eye for composition for someone who claims is a beginner
I would have no problem mounting this on a wall
very nice indeed
Randy
11-01-2016, 11:30 AM   #12
adsouza's Avatar
QuoteOriginally posted by slip Quote
very nice indeed
Randy
Thank you Randy.
07-08-2018, 04:06 PM   #13
henrikpedersen33's Avatar
Nice idea with a frame in which you have your object. Super.
07-15-2018, 12:01 PM   #14
I love the textures and the way the light is balanced between the wall and the fall scene through the window. The upper right corner is a slight distraction for me, but I don't know whether it could be cropped out without losing important elements. Overall, I think this is a really good shot.
07-17-2018, 08:24 AM   #15
Great composition.
balance, corner, critique, crop, frame, photography, pm, post, vs
Landscape Late Fall at the Gardens shiner Post Your Photos! 3 11-24-2015 11:12 AM
Nature Fall Colors at Lake Sabrina uday029 Post Your Photos! 2 10-14-2015 05:10 PM
Looking for fall photography locations in Southwest btnapa Travel, Events, and Groups 4 08-27-2015 10:35 PM
Looking at sony neostyles Canon, Nikon, Sony, and Other Camera Brands 4 12-14-2014 11:43 PM
Landscape Fall Colors at The Morton Aboretum chicagojohn Post Your Photos! 9 11-04-2014 06:06 AM
All times are GMT -7. The time now is 01:49 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
