Not at all a bad start. I can offer a few general tips.
Mode. Switch to TaV mode. These settings are a good starting point. A significant point is that most lenses are not at their best when wide open.
- Aperture - f11
- Shutter - 1/250th
- ISO - Camera looks after that. You may get noise in low light. Treat that in processing or get more light on the subject.
Manual focus. Focusing can be very tricky especially if there is any wind. Auto focus just can't do what you visualise. Actually a good method is to focus by moving the camera back and forth.
Lens. A dedicated Macro lens will give greater magnification and a shorter minimum focusing distance. There are alternatives. A good guide is this
B+H Video Isolate the subject. Often difficult especially with foliage but look for flowers that stand out from the rest.
Background. Check the background as you are shooting for any intrusions. A blotch of colour might add to or detract from the image. #1 and #2 in your series are not too bad #4 has a very messy background. Often a very slight change in angle can make all the difference.
Crop out distracting elements. Don't be afraid to crop
Depth of field. Check out a
DoF calculator for your camera/lens combo. Often it is better to stand back slightly to get better DoF and then crop to get your final image. Be aware of the background.
Take lots of photos.
Good luck
