I'm having a moment of indecision. The theme was 'eggs' and I figured to demonstrate how chocolate Easter eggs are made. I'm having trouble picking which one will end up in a projected slideshow, so I'll take any input, even a straight selection of your favorite or even least favorite
The top left was what I initially envisioned, one getting coated with a couple more in waiting. I'm thinking the clean eggs might be too subtle on a projector I have no control over. So I'm leaning towards the bottom left, with the chocolate covering process more complete, and an assembly line feel.
The top right is pretty much right out, I don't like the balance. But I did like the chocolate stream I managed to capture on the middle egg so I knocked up a quick composite on the bottom right, which has some appeal but loses the assembly line, left to right sort of flow.
Some technical nits - I wanted to keep the ISO low as I figured I might be doing a bit of finagling with the highlights. I also wanted to keep the flash power as low as possible so I could fire off multiple bursts as the chocolate poured so settled on f/8. This was a touch wide, the chocolate on the ground is getting out of focus (not so visible at this small size). Memo to self, get a means to gang up flashes inside the softbox. There's also a seam that needs cleaning up on the background (the floor is a plastic cutting board, the background is white paper).
