Originally posted by fastpitchdad Thanks for the reply and the recommendations and suggestions. I typically shoot the "action" shots in the TAv mode, with the shutter speeds around 1250 to 1600 you want me to try taking my f-stop from 4.5 & 5 & try f8 f10 115? I see the photo looks alot better in thirds. Thanks again really appreciate your time.
generally I shoot in aperture priority and let everything else sort itself
about the only time I set shutter speed is when i'm chasing hummingbirds or butterflies
whichever mode you use...
take a couple of shots
take a look at them
are they what you wanted?
yes...you're good to go
no...change a setting until you get it
NOTE: change only ONE setting at a time...otherwise you'll drown in confusion
another thing while i'm pontificating...
depth of field can make up for a missed focus...deeper DOF, a bigger slice of the scene will be in focus
one more....
my biggest weakness in catching moving objects is stopping my pan and not following through on the "swing"
that abrupt stop has lost me several nice shots
I have found that using the highest burst rate compensates for my incompetence
all that said, you're doing fine and my guess is that, like most of us, you will get where you want to go
