Originally posted by Tonytee
Thank you very much for the improvements. Which PPE did you use and how did you arrive at this result? Most Impressive.
Tonytee.
I used Photoshop with Topaz Remask as a plugin but you don't need that software for this, its just what I am comfortable with and what I have.
I first masked the background away from the subject and darkened the background. The main thing that bothered me about the original was on the left side of the rose there was another rose behind it out of focus but fairly bright. The subject rose was competing with the background rose for my attention. Darkening the background helps create a more 3D effect and isolates the subject.
Then I did a levels adjustment to add contrast, the main petal that shoots out at the viewer I felt needed a pure black under the petal to give it depth, so I used levels adjustment layer to get that.
Last I corrected the color with a levels adjustment for just red. I also had to back down the saturation a bit because it was too high (possibly due to the other levels adjustments I already did).
With more time I would work a bit more on my mask (its slightly off in some areas), the color still needs some work but I cant put my finger on it, lighten the stem slightly, do some dodge and burn on the petals to create a bit more depth. The petals on the back half of the rose can use a bit of darkening in the shadows. Basically the dodging and burning would be to create a similar effect to using a diffused off camera flash on the flower.
You definitely have a nice photo for a starting point.
