Originally posted by scotty1: There is a sudden colour change from purple to blue
I don't see any objectionable transition from purple to blue. It's a matter of opinion. In Lightroom, and maybe Rawtherapee has something similar, you can adjust the saturation and shift hue for specific colors. Play around with the blue or purple channel until you find something you like. Or maybe adjust the white balance.
The horizon colors are nice. I can't tell if that's due to light pollution or twilight, but it looks good regardless. What time was it? I usually wait 2 hours after sunset for the best Milky Way. You might have lost the good backlighting on the trees if you did that, though.
Originally posted by scotty1: 20 seconds ISO 12800 f3.2 17mm
Did you shoot in DNG or JPG? That's a very high ISO, but assuming you downsample the final image most of the noise goes away. Your 20 second shutter speed is good to keep stars from moving too much at 17mm. You might be able to get away with 30 seconds, though.
My approach with the K-5 is to use DNG and go no higher than ISO 3200 for the night sky. I might take a test shot at ISO 12800 to check my composition, then go back to ISO 3200 for the actual photo. A 20 second exposure will look dark but I later boost the shadows, white point, etc. in Lightroom.
---------- Post added 11-08-17 at 12:03 PM ----------
Originally posted by Tas hopefully you'll be good to go for March 2018
Is there something special happening then? I didn't see it mentioned elsewhere in the thread. Maybe you're just thinking ahead to when the brightest part of the Milky Way will come back after winter.
