12-12-2017, 05:31 PM   #16
I think you have two-ish options. Shoot with a prime that will be sharper at f2/f2.8 than your current lens and or upgrade to K70/K-P which would give you at least a stop more of high iso to use. f2.8 should be fine with regard to depth of field, but on many 70-200 lenses it will be just a touch soft.
12-12-2017, 08:52 PM   #17
QuoteOriginally posted by dms Quote
No--I would not reduce DOF, and also the shutter speed seems OK. Many of the shots are very good, but many would benefit from small adjustment in framing (e.g., cut off feet in otherwise full body shot). It's fine to do a major crop/zoom in, but if getting most of the body, probably want all of it.
---------- Post added 12-12-17 at 05:31 PM ----------
BTW a very high iso (above 1600 typically) is usually not a benefit. First it brings in noise, and second it reduces dynamic range.
Thank you so much. I feel like to photos are fair-to-good; I am trying to get to the good-to-great level. Wondering if investing $1K for another stop will do the trick. 😜
12-12-2017, 09:55 PM   #18
Otis Memorial Pentaxian
clackers's Avatar
QuoteOriginally posted by TXPentaxK50 Quote
Thank you so much. I feel like to photos are fair-to-good; I am trying to get to the good-to-great level. Wondering if investing $1K for another stop will do the trick. ��
I like your photos, TX. f2.8 is par for sports shooting.
You might try using a monopod to help steady the camera, and if you know the players and coaches well enough, get down out of the stands after you've done enough of the standard action shots and bring your 16/17-50 f2.8 or any faster primes along the sidelines if you have them.
There will be more hit-and-miss, but they will be more dramatic. Where you were angling down to avoid the ugliness of the signage and crowd on the other side, you would now be angling up.
The lighting is dim and crappy in volleyball/basketball stadiums, as you've discovered.
12-13-2017, 12:14 AM   #19
dms
Investing in equipment is seldom very useful--unless it lets you do something you could not do before. In this case it is about technique, not equipment.
---------- Post added 12-13-17 at 12:30 AM ----------
Looking again at your pictures, I also believe a 1/250 sec at f/4 would be better. The gain in DOF is more important than the increase in motion of the women and/or ball--after all they are moving and freezing that motion does not actually look so good (IMO).
12-13-2017, 12:40 AM   #20
Some of you guys reporting successful shots at ISO 3200 and 6400 makes me drool. It doesn’t seem the K50 is good for much beyond 1600. 2 more stops is HUGE and would allow me to do to 3.2 PLUS more shutter speed.
Is this realistic / over-simplistic? Am I blaming too much on the K50?
If people are achieving good results at ISO 3200 and 6400 with a K30 the same should be possible with a K50. A lot will depend on whether you rely on in camera noise reduction or post processing.
12-13-2017, 01:16 AM   #21
Unoriginal Poster
iheiramo's Avatar
QuoteOriginally posted by slartibartfast01 Quote
Yep. With high ISO it's important to shoot RAW and do noice reduction in PP. Software does matter. Different programs produce different results. If I needed high ISO regularly, I would test Topaz DeNoice. I've seen some stunning shots done with it here on this forum.
12-13-2017, 12:02 PM   #22
I went ahead and purchased the K-P for myself for Xmas.
Someone mentioned shooting RAW for high ISO.
I’m an old film guy so I would like to learn more about RAW, what it is, the benefits, etc.
Can someone do a brief primer or point me in the right direction ?
12-13-2017, 01:20 PM   #23
Unoriginal Poster
iheiramo's Avatar
RAW is uncompressed image format: Raw image format - Wikipedia
From camera menu you set it to record image either in compressed JPG format, which are ready to use, or in uncompressed RAW format, which need to be post processed in computer to usable format. If needed, you can also set camera to record both.
12-13-2017, 01:42 PM - 1 Like   #24
normhead's Avatar
Raw lets you make use of all the information captured by the camera. Jpeg is like taking your film to the 1 hour photo place. Raw is like having a full colour darkroom in your basement.
Here's a raw file straight off the camera.
Here's the same file after a few minutes work.
The RAW has the potential to be the better image. But there's a learning curve. You need to be willing to spend some time learning whatever software you choose. And you have to be willing to do a little bit more work on each image. Although looking at your images, the software I use allows me to work on the first file, and get it the way I want it, then copy the settings I used and apply them to all the other images taken with the same conditions. So, once you get comfortable with the software and start getting some good results, it gets easier and more efficient.
Using raw allowed me to under-expose a full stop to maintain the detail in the sunset, and then pull up the shadows for some detail along the shoreline.
12-13-2017, 03:20 PM   #25
Great! What is the most user-friendly software out there? Is there something that is web based where you upload a photo, optimize it, and save it ?
12-13-2017, 03:36 PM   #26
clackers's Avatar
Because you've got a demanding environment, you will end up doing better development of JPEGS in software than your camera does.
For starters, you don't want the same level of noise reduction being applied to the players as to the background - it destroys detail.
One of the most popular products is Adobe's Lightroom, and I sometimes use in conjunction with it the free Nik software plugins.
At some stage, you will have to get into postprocessing to take your photography to the next level.
12-13-2017, 03:42 PM   #27
Ok, so you do recommend raw for my purposes? And tell me a bit about noise reduction - the players versus the background. How is this controlled? By camera settings? Or by the software ?
Sorry for all the dumb questions. I did most of my serious stuff in the film age and am just now gearing back up to shoot my daughter’s volleyball for the next 3 years or so.
12-13-2017, 04:10 PM - 1 Like   #28
audiobomber's Avatar
You have some nice photos. The ones I thought needed improvement were mostly due to 1) white balance and 2) motion blurred faces. Raw is one solution to the white balance issue, or use a grey card to set the light temperature. Motion blur is due to too slow shutter speed, I would try 1/750 or 1/1000. For me, a motion blurred face is a spoiled image and it cannot be rescued. Better to shoot at higher speed and process for noise.
12-13-2017, 04:43 PM   #29
clackers's Avatar
Ok, so you do recommend raw for my purposes? And tell me a bit about noise reduction - the players versus the background. How is this controlled? By camera settings? Or by the software ?.
When the camera does it to make a JPG, it can do it either too much or not enough, because it has no idea about the subject matter.
It's better that you take charge in software from the RAW file itself, using the mouse to select different noise reduction levels (and types) to different areas on the screen in front of you. You can kill all grain in the background, for example, but be very cautious about faces - you can end up with wax dummies!
Photography projects with personal meaning are the best, right? The love for your daughter can give you the impetus to rediscover the hobby and push through the ups and downs of learning.
At some (much) later stage, you should attempt some flash photography, even of just warmup/practice if there's an objection to it at game time, because you can get the true colours and contrast that are masked by the dingy stadium lighting and hopefully get some vivid pictures of what's an exciting sport.
12-13-2017, 04:44 PM   #30
clackers's Avatar
QuoteOriginally posted by audiobomber Quote
Yeah, 1/500 can be fine for the serves and team gatherings if the timing's right on the shutter, but is much too slow for general play.
action, body, camera, critique, equipment, f2.8, freeze, help, ii, iso, iv, k-70, motion, photography, photos, shots, shutter, volleyball
Sports Volleyball Reportage Photos (part 2) ... without a ball ;) edri Post Your Photos! 2 06-08-2017 01:55 AM
Sports Volleyball Reportage Photos edri Post Your Photos! 10 05-29-2017 01:20 PM
My first paid assignment: indoor volleyball – any tips? bwDraco Photographic Technique 33 12-08-2015 05:14 PM
Please. Please. Please resell me on Pentax Buschmaster Pentax DSLR Discussion 31 10-10-2012 08:38 PM
Perfect volleyball shots JCSullivan Post Your Photos! 3 11-07-2007 07:59 AM
All times are GMT -7. The time now is 08:59 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
