Hi
Indeed nice shot.
I think correcting lens distortions would help, because even minor distortions can be very noticeable and annoying. The slight bow of the horizon for example.
Next, correcting colour would make the image more pleasing to look at and more realistic. I personally don't like the uniform unnatural purple, it makes the blues, yellows and reds loose their impact.
All I did is import the image into Oloneo PhotoEngine to remove the colour cast. Oloneo is particularly good at this. The colour picker has the ability to select an extremely minute area down to pixel level with an as near as possible neutral gray value. sRGB (R128,G128,B128) When an image has a true colour cast and you select this small spot the cast is removed and the true colour is revealed. The result see below.
The only other thing I did was to increase overall saturation a wee bit, and I mean just a wee bit.
There you are, what do you think ?
