Originally posted by jawats I do try to have fun, even when it's still in the 30s in late May.
Cold is good when shooting the Moon, as long as it doesn't come with moist.
Some tips:
Use a tripod.
The closer to vertical you shoot, the less atmosphere (and dust and moisture) will be in your way (there is 50% more atmosphere at 30° than at 90°, 23% at 45°)
Try your sharpest aperture (normally around f8 - f11)
Try your best ISO setting (normally 100 or 200)
Aim for a shutter speed of 1/125 or faster.
Slightly under expose.
Use 2 second timer with or without remote.
Use magnified Live View to focus.
Take a shot and see if it's ok then take several (or dozens of) shots at each setting as the atmospherics keep changing and two shots a second apart can be very different.
