11-19-2018, 08:41 PM   #1
Help with moon shots
Lens: DA*300 Camera: K-50
K-50 with DA*300. No filter. Shake reduction off. Manfrotto 3021Pro. 12 second timer. Autofocus.
I'm going in for cataract surgery, but I think photo quality is being affected by technique or equipment.
Suggestions please.
PENTAX K-50  Photo
PENTAX K-50  Photo
PENTAX K-50  Photo
11-19-2018, 08:54 PM   #2
I would "manual focus" instead of autofocus. Find subject at infinity distance to manual focus then point the camera at the moon.
11-19-2018, 09:15 PM   #3
12 seconds? I used 1/200 second for mine because I usually get some blur when I use long exposures with the moon (took me a while to figure that out). You can look at these, see what you think, and use the EXIF data for a reference.
https://flic.kr/s/aHskNMHiDg
11-19-2018, 09:38 PM   #4
I am no expert but have taken several moon shots, and I agree with jspi, I think your exposure is way too long. I looked at one where I used a Sigma 120-400 and shot at 400mm at f29, 1/50th of a second and ISO200 (I am not sure why I didn't go at ISO 100 and open it up a stop). It was certainly not perfect, but was pretty sharp.
11-19-2018, 09:48 PM   #5
GeoJerry's Avatar
Your EXIF says the shutter speed was 1/100 sec, so I assume by "12 second timer" you mean you activated the timer in order to eliminate shake due to pressing the shutter. A 12 second exposure of the moon would be OOF but I have to believe your EXIF. I think the problem may be your use of autofocus mode. I don't know the K-50, but does it have a spot focus mode? If so, try using that after you've centered the lens on the moon.
11-20-2018, 09:45 AM   #6
UncleVanya's Avatar
On the k-50 you are better off using the 2 second self timer. The 2 second version flips the mirror up and does not drop it before the shot as far as I recall. This is the best way to reduce mirror induced shake. The 12 second timer from what I recall flips the mirror down and back up right before the shot.
Also with moon shots I tend to use a little higher ISO and higher shutter speed if I'm recalling correctly.
---------- Post added 11-20-18 at 11:46 AM ----------
What head on the tripod? Steady? Balanced weight with lens and body?
---------- Post added 11-20-18 at 11:47 AM ----------
I use live view manual focus on my shots and look carefully at the focus peaking. The edges are good for this.
11-20-2018, 12:25 PM   #7
I'll echo the comments suggesting manual focus.
If you still want to try autofocus, do it via liveview and set focus point over the edge of the moon. That gives a high contrast target. It also removes the possibility of lens focus calibration needing to be fine-tuned.
11-20-2018, 06:54 PM   #8
Closed Account
Rnovo's Avatar
Photographing the moon is like working in broad daylight, same exposures, the sun illuminating the moon is like the sun on earth - don't be fooled by the black sky and use "manual exposure" so nothing will change as you keep shooting. As for focusing I agree with all who suggest using live view. I don't know the K50 but on the K5 I press the "Info" button repeatedly to zoom up to X 6 and only then do I focus in "manual", shoot and repeat as required. I never use any AF - too unreliable and useless. Focus peaking sounds good too, as says UncleVania - never tried it(?).
11-21-2018, 02:13 PM   #9
UncleVanya's Avatar
QuoteOriginally posted by Rnovo Quote
I think the K5 lacks focus peaking. I use the magnified focus and focus peaking both.
11-23-2018, 10:26 AM   #10
Larrymc's Avatar
QuoteOriginally posted by Banskojoe Quote
Suggestions please.
As others have said use live view with focus peaking zoomed in and focus manually. The moon is travelling through space at over 2200 miles per hour so you need a reasonably fast shutter speed even at this relative distance also use spot metering. Also use either a wireless shutter release or a wired one. after focusing you shouldn't need to refocus during shots unless you missed on the first try. After manual focusing with focus peaking and before triggering the shutter let the camera and tripod settle down for a few seconds to reduce oscillation induced by focusing.
Here is a shot taken in 2014 with my K-50 if you care to check the EXIF just click on the image and go to Flickr to look at the camera setting in the EXIF file. This was taken with an older Sigma 70-300mm F4-5.6 APO DG Macro zoom not the sharpest out there for sure.
11-26-2018, 10:58 PM   #11
Pelto's Avatar
Also read ‘Astro beginners guide to shooting the moon’ by MossyRocks : Beginners guide to shooting the moon - PentaxForums.com
11-27-2018, 02:35 AM   #12
ZombieArmy's Avatar
I don't use peaking for any astro target. At least on the k-01 it's just wildly inaccurate.
11-27-2018, 10:02 AM   #13
UncleVanya's Avatar
QuoteOriginally posted by ZombieArmy Quote
I've never used it EXCEPT for the moon. On the edge of the moon I find it helpful. This is particularly true with the FA* 300 with stacked TC's (1.4 and 1.7).
11-27-2018, 10:30 AM   #14
pschlute's Avatar
Problem is either focus (try the methods suggested above), or mirror/shutter vibration. You don't have the option for electronic shutter on the K50 so try to get the shutter speed above 1/250. No need to use f11, use f5.6
11-27-2018, 10:59 AM   #15
UncleVanya's Avatar
Depending on the lens it could help with CA... but so would conversion to B&W.
camera, focus, mirror, photo, post, shot, shots, timer
February Moon (feel free to post your moon shots) GLThorne Post Your Photos! 11 05-02-2016 12:00 PM
K3 Moon versus K5 iis moon pearsaab Pentax K-3 & K-3 II 19 11-15-2013 06:39 PM
Nature Moon shots (yop, one more thread on the moon) Martin_Qc Post Your Photos! 3 05-25-2010 10:01 PM
moon and only moon vsmouli Post Your Photos! 4 08-26-2009 04:04 PM
3 Moon Shots From Today Help ! daacon Post Your Photos! 10 01-25-2008 10:41 AM
All times are GMT -7. The time now is 12:29 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
