Originally posted by pattik I posted in another forum asking how to take the following pics today. Apparently I still couldn't get it right. Remember I am new to the digital SLR era (so please be gentle) and so far, I'm not liking it
I would really like to figure this out but am getting so frustrated along the way.
Anyway, this is what I've got and I really hope I do this right so you can see my awful pic.
It was cloudy, I shot these on a tripod with my Tam 28-80 f/4-5.6 in shut & ap priority mode at F11 at 45 mm. Why are they so dark? I thought that mode was supposed to pick the right shutter speed to let in the right amount of light. Besides being dark, I think they are grainy.
Well, from the EXIF, it says iso 400, and 1/125 for shutter speed, and 40mm focal length.
You have 8 people crammed together up front, so figure about 18 inches each, so about 20 feet across the frame. Assuming you are using the built in flash, it jsut doesn't have the oomph to pull that off at f11, even at iso 800. The only reason the first shot is as bright as it is is due to the setting sunlight. Bump it back to f 8.o if it doesn't wreck the DOF, and bring the shutter speed down to something slower like 1/60th or 1/30th, and you would have been much closer to what you wanted.
The second one is closer, but it appears the sun is helping less, so you still don't have enough light make the trip there and back.
As for grainy, I can't say with them reduced in size so. Don't judge chroma and luma noise by 100% views, you simply aren't supposed to be looking at a 100% image up close on a monitor. You'd never do the same with film except if working on an enlargement in the darkroom, and much the same happens. At this size, there isn't much noise, but that much scaling will hide a lot of noise. Generally at 400, the k10d should be pretty well controlled on noise. 800 is borderline and depends on the pic. post processing can bring out noise in anything though.
