Originally posted by dLSK It's a decent enough image. Some points to ponder:
- right side branch, very distracting as it exits the frame unfinished
- foreground reflection is a distraction : too much or not enough reflection. Would either take the image closer to where the tree touches the water OR pan back a fair amount and get all tree / all reflection
- the tree / root in the water half submerged ( to left side and behind some the subject tree ), big distraction. Takes away the separation of subject and background.
- I feel, overall, there is too much of your main subject not in frame
- overall, as well, just too busy. The branches, the grasses in the water (fore ground and background to right ) all compete for the eye , and takes away from your main subject.
- there is a weird halo in between branches + background sky. I can see it in the colour image, but it's much more predominant in the B+W
- overall the B+W conversion is flat. The reflection, background area, and the branches are all the same tone. Mountains could be darkened to fix that, add a bit of contrast.
Hope these tips help
Thanks. I think your suggestion on composition - cropping the water area below the tree might makes sense, I'll give that a go and see how it looks. Aside from that, the location of the adjacent tree does not allow for backing camera away (wider focal length) to 'isolate' this one tree and all it's branches against the background - attached is a pic showing the scene but from another angle (pic is direct from camera so it's 'dull') - camera position for the image I converted to b/w is from on the small grassy mound just to the left of the tree (tree I shot is on left in this image). The sun was rising almost directly behind me, it was 12 mins. after sunrise, I was done shooting and on my way to the car when I turned to see the tree. I think the 'halo' you see is likely the light/color in the distant sky and/or maybe a combination of that along with taking a large raw file and compression it to upload here - raw file it looks tad bit different in that respect.
I'm going to play with the b/w conversion - I am like many, my first inclination on b/w is to move towards heavier contrast for 'snap', etc. That might be effective, I'm going to play with it and continue also along the 'soft look' too.
Thanks/Bill
