It's a beautiful area worth exploring in all kinds of weather and times of day. If you can return to the area, try to shoot when the light is less flat (flat meaning there are no shadows). At the same time you want to avoid hard shadows, but without any shadow you can't perceive the distance and size of things well. You could achieve this at dusk/dawn, but also just waiting around if the clouds look interesting. And if you find that clouds or haze are moving in and out, wait a bit to see what happens, even 15 minutes can make a significant difference. Have your camera ready, ideally on a tripod with a composition framed, and pay attention to how the landscape changes.
The snow on the mountains looks more interesting because of that, so another thing to try is using longer focal lengths to pick from the landscape what makes it interesting.
With this frame, I would crop the left part of the image and leave the river to lead to those green trees. I tried 10:8 aspect ratio keeping the full height of the image and it seems to work a little better. As it is, the peak on the left is distracting for me because it's very obvious, but there's nothing brighter in the bottom of the image to balance it and the rest of the elements don't lead to it either.
It is underexposed, check the histogram, I downloaded the photo and darktable shows the brightest part is well below clipping (and it's from clouds and snow, which should be bright in this light).
