10-01-2019, 10:45 AM   #1
Custom User Title
FozzFoster's Avatar
Too Much Lean For Real Estate?
Lens: Sigma 10-20mm Camera: Pentax K-S2 Photo Location: Edmonton ISO: 320 Shutter Speed: 1/80s Aperture: F8
What are your thoughts on the amount of lean this shot has?
I know it's sacrilege to have leaning lines in architecture...
I usually level my camera perfectly. However, for this shot I tried to get more in the frame and needed to tilt the lens which causes a lean on all my straight lines.
I can adjust the straightness in Lightroom, but when cropped a lot of the image is removed.
Is it too distracting in this photo?
Thoughts?
Thanks!
PENTAX K-S2  Photo
10-01-2019, 10:58 AM - 1 Like   #2
MossyRocks's Avatar
I think that there is too much lean. It kind of reminds me of those houses you see on stilts on the sides of cliffs where it looks like it is ready to fall over at any minute. I would think this could be managed better by shooting at a different height and angle but I haven't done any real estate shooting so I could be completely wrong about that.
10-01-2019, 11:04 AM   #3
Custom User Title
FozzFoster's Avatar
QuoteOriginally posted by MossyRocks Quote
Thank you for sharing your opinion!
10-01-2019, 11:06 AM - 1 Like   #4
dms
As a consumer I would think so, and as a photographer most certainly IMO. Attached is a quick adjustment using perspective and skew in photoshop. I think these corrections should be available in most pp software as they don't require (AFAIK) layers. And it does not seem to really detract from the feeling/elements of the space (again IMO).
PENTAX K-S2  Photo
10-01-2019, 11:15 AM   #5
Custom User Title
FozzFoster's Avatar
QuoteOriginally posted by dms Quote
Yes! I totally agree.. I was curious how much I might be able to get away with.. haha not much I guess!
Thanks for showing me this!
I had used Lightrooms corrections (I'm still very new at Photoshop) and I didn't like the results at all, attached.
You can see much more of the ceiling in your example - great work!
I guess it's just a post-processing talent/ learning curve thing then, eh?
Thanks again!
PENTAX K-S2  Photo
PENTAX K-S2  Photo
10-01-2019, 11:24 AM - 1 Like   #6
There's a strange interaction between your skew, the shape of the rooms and the shape of that counter.
It looks like a kaleidoscope! It could be interesting as an image but I'm personally close to dogmatic about vertical verticals in architecture shots.
10-01-2019, 11:24 AM - 1 Like   #7
dms
There are at least three or four alternatives.
1. Get a wider FL lens. A fisheye w/ Fisheye-Hemi (software) correction
2. Take a couple of photos (spaced horizontally) and then merged w/ a panorama function/software
3. Use post processing as I did--the major ones (as I mentioned I used in Photoshop) being perspective control and skew
4. Get a Perspective Control Lens. A 28mm PC lens on FF is my guess as what would do it. Or possibly a 35mm one (Nikon) and combine w/ item 2 w/ lens shift (again FF).
Last edited by dms; 10-01-2019 at 11:28 AM. Reason: Clarify (the item 4) 35mm shift is for FF.
10-01-2019, 11:26 AM   #8
Custom User Title
FozzFoster's Avatar
QuoteOriginally posted by house Quote
Thank you for your feedback!
10-01-2019, 11:37 AM - 1 Like   #9
dms
Your welcome.
BTW for some reason I thought you used 20mm on cropped sensor, as it was 11mm my speculating about 28mm PC lens was wrong/ditto for 35mm PC lens.
10-01-2019, 01:19 PM - 1 Like   #10
Gerbermiester's Avatar
I agree with the comments above. But, also consider adding off camera bounce flash to the frame to help balance the outdoor exposure.
Real Estate Photography Flash Setup
10-01-2019, 01:51 PM - 1 Like   #11
swanlefitte's Avatar
+1 to too much. It photo does good at showing the flow thru but at the expense of giving a surreal feel that is off putting.
Confined areas are hard. It's hard to get both a good image and capture the reality. I have reshot rooms many many times to succeed. I envy those who can do it fast and get it right.
10-02-2019, 06:13 AM   #12
Custom User Title
FozzFoster's Avatar
QuoteOriginally posted by Gerbermiester Quote
QuoteOriginally posted by swanlefitte Quote
Thanks again for all the feedback!
10-04-2019, 09:22 PM   #13
Definitely needs to be the lean corrected. Like the fixes given above
10-05-2019, 07:33 AM   #14
Custom User Title
FozzFoster's Avatar
QuoteOriginally posted by shaolen Quote
thanks for commenting
10-05-2019, 03:39 PM   #15
Sure. And yeah I mean maybe if the client really wants and is ok with *some* distortion like that but otherwise never allow distortion. Also never be afraid to *not* go your widest
critique, lines, photography, shot
Real Estate Photography - Awful Colours FozzFoster Troubleshooting and Beginner Help 30 07-05-2019 07:12 PM
Real estate exercise, which lens(es)? redmenace Photographic Technique 23 10-02-2018 06:27 PM
Nature Another person with too much money and too much time Murra54 Post Your Photos! 10 02-15-2016 09:14 PM
Streets Lean, Lean, TOILET!!! 45 Mike Post Your Photos! 2 04-21-2015 10:41 AM
When is too much, too much? lbenac Film SLRs and Compact Film Cameras 15 05-03-2009 04:49 PM
All times are GMT -7. The time now is 12:11 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
