Originally posted by JonPB To directly answer your question--100% does not refer to frame size. 100% does not mean "every part of the frame is included." Rather, 100% means "every pixel is included." A 60% view is not a 100% view. If you zoom to 100%, some of the image will be off of your screen; that creates a visual crop of the image.
A 60% view is not a 100% view is correct, but you are still using the original image just at a smaller magnification. If I'm viewing the original 14.6MP image at 60% of it's actual size and crop off that, I'm
reasonably sure the software is going to crop the 100% image and not your 'to scale' view. This being said, if you are VIEWING at 60% and crop an area and then blow it up to 100% (by now you should be able to view 100% of the area) you should be
pixel identical to the same dimensional crop if you had cropped right off 100% magnification view.
*This is based on the assumption that the crop tool isn't cropping the 'compressed' view of the image. Which would just be damned silly.
