Originally posted by robgski I like the colors, patterns and textures. I do think the crop at top and bottom should have allowed for the brackets on the post to be fully in the frame , cutting off objects throws off the final result, IMO.
Another idea would be using a square crop, a picture like this could be an album cover.
I had similar thoughts on the framing but due to only having my 300mm with me I couldn't get farther back unless I was falling off the bridge. It is a shot I want to go and redo in the near future using a shorter lens like my S-M-C 200/4 Takumar or D FA 100/2.8 WR Macro so that I have some more options for framing. I do like the thought of using a square crop but still would have like to have a bit more space above and below the cable tensioners.
Originally posted by Fdooch But ... it is very embarrassing that the top and bottom are very pressed to the edges. I want to add half the space between cables
I wanted that as well but couldn't manage with what I had at the time. That is probably the biggest issue I have with the image and kind of wanted to see if others had it as well or if it was just my somewhat broken mind finding an issue where there really wasn't one.
Originally posted by Fdooch And it can be flip horizontally. The restriction on the right side is psychologically perceived as wrong
That is something I hadn't thought about before but is something I will probably consider in the future. I am planning on reshooting it as it is only a short drive and instead of only going with gear for birds at a distance bringing all my stuff.
