Originally posted by Fdooch To all of the above, I want to add that a slightly longer exposure would have improved the water jets, especially in the lower part.
Thank you for the suggestion, I will post a shot taken with a longer exposure... (even if not very long).
Best regards,
maurizio
---------- Post added 18-12-21 at 12:11 PM ----------
Originally posted by dneira29 sounds like it gets heavy real quick haha. How do you like using your 15-30??
Hi dneira29, I like very much the DF 15-30! It is my most used lens.... It delivers beautiful colors and contrast, and excellent sharpness on the whole frame and on the whole focal range (especially at f8-f11, but it is very good also at wider apertures). At 20mm, I find it better (for contrast and corner sharpness) than my beloved old FA 20mm f2.8; at 30mm, I find it not very distant (for landscape and nature shots) from the excellent FA smc 31 limited. The resistence to flare is good but not perfect, some reflexes can appear when the sun is in frame (I guess this is unaivodable due to the complex optical scheme). The absence of a filter mount can be overcome by buying third-part filter holders for 150mm filters, made for the very similar 15-30 Tamron lens. It is big and quite heavy (and much bigger with the filter holder mounted), of course...
---------- Post added 18-12-21 at 12:14 PM ----------
Originally posted by ehrwien I think the crop of the first version works in deemphasizing the lower section.
The second shot succeeds in showing the continuity of the stream, and it working out to following the main diagonal works really well imho.
In the third one I see a nice juxtaposition of the massive dark boulder on the right and the colourful trees and leaves on the left, separated by the waterfall. This could perhaps work even better in this shot without including all of the flowing water in the lower half?
Hi ehrwien, thanks for your interesting comments! Following your suggestion, I will post a version of the last shot where a part of the water flow in the lower part has been cleaved...
---------- Post added 18-12-21 at 12:16 PM ----------
Originally posted by kiwi_jono All these photos look really good to me but I really like the last one you posted as it just feels the most satisfying to me.
Hello kiwi_jono, thank you for the kind comments, very much appreciated!
Best regards, Maurizio
---------- Post added 18-12-21 at 12:18 PM ----------
Originally posted by vinbenito Hi ! Yes the last one is my favourite ! good job !
Hi vinbenito, thank you so much foir the kind and encouraging comment!
Warm regards,
Maurizio
