Originally posted by Myoptimism Testing a new lens, and would like critique of my shot. Thanks.
I don't know about "compression artifacts" and such, but I have some issues with the composition: I see too much stuff on the left but too little on the right ; the diagonal takes the eye across the image from left to right but there's nothing there when I follow it and there's nothing to bring me back into the image; the equipment is either too small, or too large,
vis a vis the image, plus it's the same size and vertical as the tree, so I don't know which I'm intended to focus on; and there are too many "lines" going at odd angles.
If these points are valid, what to do? I'd like to see another lower/tighter POV that crops right below the far trees and close to the left of the equipment, then have the fence line bring me forward. Not better, just different,
Brian
