Cory,
Very nice capture. This looks like Hocking Hills to me. I think your biggest problem is sharpness. However, there is a ton of detail in the rocks that could also be brought out and I think a standard 4x6 ratio crop to remove some of the right side of the image would help also.
Here is my work up of you image.
Processing steps with Paint Shop Pro
1) Levels adjustment: bump gamma to 1.38
2) A double USM adjustment per Ben Kanarek's method
Benjamin Kanarek post processing method | PentaxLife
I desaturated the duplicate layer and set the opacity to 40%
3) Slight Curves adjustment on the bottom half of the curve to bump the contrast in the rocks.
3) High Pass Sharpen: Radius 1 Strength 83 Overlay mode.
I think if you resubmit something like this you will get accepted.
Tim
