11-17-2009, 03:58 PM   #1
Landscape
Lens: 18mm Camera: K10 ISO: 100 Shutter Speed: 1/500s Aperture: F8
First-I truly appreciate the members here for their participation. It is nice to look at other's critiques as well to give me some perspective. Thanks in advance.
I've been kicking around some PP programs and wanted to get a perspective. This was a bit flat but I was able to kick it up a bit in Corel Photopaint. It has an auto-correct of sorts and it adjusted the photo automatically for brightness, color and intensity. Let me know if it is over-done? I'm new so this looks "just great" to me!
Last edited by J-Rod; 11-17-2009 at 04:11 PM. Reason: I can't see the image....sorry. Got it now!
11-17-2009, 05:36 PM   #2
Damn Brit
Guest
It looks overdone to me. Is you're monitor calibrated? If not, you are probably seeing something completely different to most of the rest of us.
From a composition point of view, the ideal shot from this (to me) would be, if you crop it as I say, you'll see what I mean - Crop a little from the bottom, then you'll have a diagonal coming out of the bottom left hand corner. Crop a little from the right to remove that little piece of hill that starts going downhill out of the frame. Crop the sky down to the top of the right hand diagonal cloud, there's too much sky.
11-17-2009, 08:01 PM   #3
K-9
Too much blue. Try toning that down.
11-17-2009, 08:27 PM   #4
DB--crop per your instructions. My monitor isn't calibrated but I think it is close. I thought it was a bit "overdone" but also thought it looked decent. I do like it with your crop. I also tempered the blue by decreasing the contrast slightly.
Thanks!
11-17-2009, 09:39 PM   #5
Damn Brit
Guest
You have had your first composition lesson Grasshopper.
Now the trick is to get it like that without having to crop.
11-18-2009, 07:45 AM   #6
Thanks! It truly does look better. I appreciate it and will work on not cropping in the future. I think I can make it happen!
11-20-2009, 03:39 PM   #7
MRRiley's Avatar
The blue in the sky and in the distant mountains still needs to come down. I think part of the problem is that even the clouds have a blue cast and this makes everything else look off. If they didnt have the color cast, the rest of the blue might look ok.
I'd also pull some yellow out of the midrange mountains and the foreground.
Like the composition though. original is OK, 2nd much better...
Mike
bit, critique, perspective, photography
kx for landscape kuau Pentax DSLR Discussion 14 07-17-2010 06:03 PM
BW landscape drmartin Post Your Photos! 2 08-22-2009 10:22 AM
Landscape MarkoP Photo Critique 4 07-23-2009 07:39 AM
Please CC Landscape Redmanll34 Post Your Photos! 5 09-22-2007 10:36 PM
landscape tipentax38 Post Your Photos! 7 03-23-2007 06:35 PM
All times are GMT -7. The time now is 11:05 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
