Originally posted by summatusmentis I'm not sure I like how blue it turned out, thoughts?
That'll be your White Balance, I'm assuming you used Auto WB and while it works for a lot of situations, it won't work for all that's why it's always best to check. Most PP software will enable you to correct this image to some extent.
As for the picture itself, not very interesting. The really interesting subject matter in those conditions are the leafless trees looming like ghosts. Get closer so that they populate more of the sky and shoot up through them.
Unless you've got something interesting in the foreground, a shot like this doesn't really benefit from having one. Having said that, for this particular shot, if you had got closer to those trees and then got down on the ground to shoot up through the grass and on through the trees, that kind of thing would work.
