Originally posted by 16N64 Looks like home.
Great critique there, I'm sure we all learned a lot from that.
I too like the silhouetted cityscapes. The problem I have with this one is the dark area is too wide and the strip of water isn't wide enough to balance it out. If you had pointed the camera down a little so you lost that grey strip at the top of the frame and replaced it with more water, it would be better balanced and you would also have a bigger area of the suns reflection to add interest. Usually all you need is the rooftops making the silhouette because that is where the interest is.
The sun is blown out pretty badly and that diagonal going through the steeple on the left is a bit of a shame.
The fortunate thing is, cities don't have a habit of moving so it will still be there to capture again.
