So, my wife and I got back from our Alaska cruise earlier in the month.I thought I would follow up with my experiences and how things worked out. (There are two things about unsolicited feedback – it's free, and it's your choice as to whether to utilize it or not based on your own situation.)
It rained five of the seven days while we were in Alaska. I have a K-3(1st generation) camera. I can indeed attest to the water resistance of the camera and kit 18-55mm lens. A problem, that I had to quickly find a solution to, was using other lenses that aren't necessarily water resistant. The cruise ship offered a rather unique solution – Egyptian cotton face cloths. Standard lens cloths cannot deal with the volume of water that we experienced in the rain. Our ship had well laundered cotton face cloths that were luxurious, super absorbent as well as lint-free. We were whale-watching in Juneau and it wasraining practically the whole time. Fresh water was constantly getting on mylens and front lens element. One of the ship's face cloths continuously wiped the lens element dry without any streaks nor lint and I was able to keep theoutside of the lens relatively dry as well. I'll be going out and buying this inexpensive item to add to my bag so I can do more wet weather photography.
I purchased a 3 Legged Thing ORII-FB L-Bracket to attach to my K-3 with battery grip. It is large enough to fit both the offset tripod screw on the bottom as well as extend all the way up to the top of the camera along one side. It was very useful for switching back and forth from landscape to portrait formats. Besides the amusing packaging that it came in, it also comes with a very clever and very useful clip that has a Allen Key and slotted screwdriver (like flat edged coin) that is integrated into a carabiner (a shackle with a loop that has a spring-loaded gate.) This can be used to tighten the L bracket to the camera and then clip easily onto a loop that is on the shoulder strap of my Lowepro backpack. This accessory is also useful for attaching or tightening so many other things camera related as well!
Before the trip, I also purchased a Manfrotto BeFree MKBFRA4GY-BH traveltripod. It's a lot lighter and more compact than my trusty Manfrotto Model 055tripod and fit easily into my suitcase. It works okay when low to the ground.When fully extended, it seemed to less stable that I had hoped for. I used mirror lock-up when taking photos with it because I was concerned about camera vibrations.When doing some night photography in Seattle and Victoria, I was glad to havethe tripod and was able to get long shutter speed shots I wouldn't have been able to make without it as a result. The bag for the tripod came with a nylon loop at one end. While carrying a backpack and tripod case all day was a bit ofa pain (literally!), I was inspired by my 3 Legged Thing accessory. I went to an Ace Hardware store in Seattle and purchased a steel carabiner and threaded it through the loop on the bag. I was then able to clip the tripod onto the other shoulder strap of my backpack. That made it MUCH easier to lug the tripod around.
To go with my tripod and L Bracket, I needed some Arca-Swiss adaptability.The Desmond DBA-2 60mm Arca & Manfrotto Compatible Clamp worked well. With an adapter inserted into the large threaded hole, it fit well into the tripod plate. (The Manfrotto plate also inserted into the DBA-2.) This made it very easy to flip back and forth from landscape to portrait formats using the L Bracket when working a scene.
I ditched the traditional camera neck strap and went with the Sun-Sniper Strap with Rotaball Connector attached to a Cotton Carrier Hand Strap - with Arca Swiss-compatible mini-plate. It was a lot easier on the neck and the Sun-Sniper attached easily to the Cotton mini plate. If I needed to put the camera on the tripod, I unscrewed the Sun-Sniper and popped it on the DBA-2. The hand strap gave me extra security that I wasn't going to drop the camera.
I brought a total of seven (7) camera batteries with me. I bought them inexpensively in pairs on Amazon and they came with a USB charger that could charge two batteries at once. This is also your "get out of jail free" card, as Matt Granger put it. If you ever get asked to check your camera bag, say"no" because Lithium batteries cannot be stored in the plane's cargo space. There is no argument then.
My panorama set-up, which I posted about elsewhere in the Forum, worked well. I took the advice of Bryan Peterson with regards to using an FLW filter for sunsets and the only two sunsets of the trips were beauties that were made even better in-camera with the filter.
I hadn't been much of a fan of using Live View before the trip, but there were several times where I used it to my advantage. It was especially helpful for low angle shots. I'm using the Live view a bit more often now since I have been home.
While it turned out I didn't need them, I was glad to have a Ziploc Big Bags, Jumbo (20 gallon; 2 ft x 2.67 ft) size. This would easily allow my backpack to fit in it if I needed to get extra protection against water.
Other cruise related things:
Even though we had pre-paid the gratuities, we tipped our steward an additional US$20 on the first day. We got exceptional and preferential service after that.We gave him another $40 at the end of the cruise.
If you get exceptional service, note their names and write them on a feedback card or e-survey. They get extra perks when guests speak of, and rate them,highly.
Bring electrical tape. If you don't need it to cover the leads of your lithium batteries, you can use it to tape over the peep hole on the door at night if you have an inside cabin. The light really is bright and a distraction if you are a light sleeper. I also brought two LED compact flashlights for night photography, and they turned out to be useful if one of us had to get up in the middle of the night to use the throne room.
Don't bother to bring power bars – they will be confiscated. You also have to go through airport-like security every time you get back on the ship,so don't think about buying them on shore leave. We also saw people with bottles of alcoholic beverages get confiscated when they tried to bring them on-board after their shore excursion.
On our ship, you couldn't get anything extra without showing your stateroom card, which was good because that meant that no one could charge anything to your room without you realizing it.
In Canada, you no longer need to call the credit card company to let them know that you are travelling. They have sophisticated ways to know that it is you that is making any purchases.
Put anything liquid into a Ziplock bag before packing it into your suitcase. I had a leak, but it was contained within the bag. Put your clothes in garbage bags. My wife's suitcase got left out in the rain by the airline and her clothes got wet. Fortunately, the clothes were dirty and it was on the return flight to home.
Bring two rolls of toilet paper, if you prefer not to use the cheap stuff that is supplied by the ship. Even toilet paper used by cruise ships can be sourced from China!
Make sure that if you use your own reusable water bottles that you dump any remaining water out at the connecting airport before you go through security again. The X-Ray machines flag the water and you get extra scrutiny as your reward. They just end up dumping the water out anyway, but we almost missed our connection.
Bring Post-It Notes – they were really useful to communicate back and forth with the Steward if you needed something, or just want to treat them like what they do matters.
While we can't get it in Canada, Meclizine HCI worked well as an anti-nauseate.It didn't cause any perceptible drowsiness. We picked up this over-the-counter medication when we were in Seattle.
Make sure that you have a really good rain coat in Alaska. My Adidas ClimaProof rain jacket, with a baseball cap underneath the hood, held up really well.
If you are going to gamble at the on-board casino, your best odds of winning are on the first few days because they want the winners to talk about winning, and advertise how much people won in the daily newsletter you receive.The odds of winning dramatically decrease as the cruise goes on because the casinos are not regulated in international waters.
Remember to bring your passports and stateroom plastic card when going on excursions. You will need them to get back on-board the ship. Keep passports in a Ziplock bag to keep them dry.
I took about 1800 shots, many of which were bracketed (for HDR) or for panoramas. I took about 400 shots of the crochet group that my wife was in.Turns out that I didn't need all the SD cards I brought, but it was good to have them nonetheless. You know what they say – better to have them and not need them than to need them and not have them. I printed 110 photos off, and my wife then added another 90 more, for the album which she put together. If the relatives were interested, I only subjected them to the original 110 through a Google Photos link. I still have my work cut out for me learning and using LightRoom to tweak things.
That's it for now!
