06-08-2021, 04:53 PM   #17671
MarkJerling's Avatar
Aha, thanks. It's right there! Shows you what I know about LR.
06-08-2021, 05:32 PM   #17672
Arpe's Avatar
The problem i had with embedding edits in DNG files was it created way more backup data. If I now edit a raw file and save it in the very small xmp file, it's just that file that get backed up, not the whole raw file. Not a problem for some, but it was for me.
06-08-2021, 05:38 PM   #17673
zkarj's Avatar
QuoteOriginally posted by MarkJerling Quote
Can you show how to customise Lightroom to write to the DNG files? Mine does not do it and it sounds like a handy idea.
One of the icons that appears on the frames in Grid view (possibly optionally?) tells you which images have out of sync metadata (either you've changed it in LR and not written to file or the file had changed but LR hasn't updated its database). You can click that icon to sync them (appears in top right corner of each frame). You can also filter by the metadata status. My approach is to have it not automatically write, but every so often I will set the filter, select all images shown, and click one of the icons. They all get read/written in no time at all.
QuoteOriginally posted by Arpe Quote
Yes, a very real consideration.
06-09-2021, 07:05 PM   #17674
Transit's Avatar
Thanks Mate I'll have a squis at Picasa :-)
Have you ever tried Picasa?
I used it for a long time and it supports DNG files.
It is weak on local adjustments and limited regarding other adjustments, but it might suit you.
IIRC, it has a big "Export" (develop) button in the interface.
It is not longer supported, but that need not deter you, if you can download it from somewhere and it runs fine on your machine.
It depends.
Some software give DNG files a generic treatment and only uses dedicated development presets for .PEF files. Most of the time, however, you should be able to work around that and create your own preferred DNG default processing.
I use DNG files because they allow me to use any decent software, i.e., I'm not dependent on specific camera model support being available.
06-09-2021, 08:18 PM   #17675
I think that's a reason why Adobe made the feature optional in Lightroom. If you do most of your changes immediately after importing images, it makes sense to have them embedded in the file, but if you do them a long way down the track then it will create larger backups.
Incidentally, Adobe Camera Raw also stores metadata changes to DNG files, and in that case I'm not sure if it gives you the option
Quote: "Adjustments are stored as metadata in an accompanying sidecar file, in a database, or in the file itself (in the case of DNG format)"
Lightroom has the advantage that it's optional, even though it uses the ACR engine for adjustments.
jpg and tiff files also support embedded metadata, and with Adobe at least, will include the full edit history, although with Photoshop the edits aren't reversible, the data of the edit history is still potentially saved to file, so trying to claim "It wasn't Photoshopped, Honest!" might not carry much weight if the file contains metadata about the edit history.
06-10-2021, 06:35 PM   #17676
zkarj's Avatar
Another flex from Adobe on the "will it or won't it?" of Lightroom Classic library access without a paid subscription.
I saw news items about the release of the first Apple Silicon-native version so of course I had to go download it. I had to find my way past a couple of obfuscations that suggested I had to buy to upgrade and eventually got it to update. When it launched I got the usual "What's new" pop-up and then the familiar "Please subscribe" window. Except now, instead of saying "Close this window to quit Lightroom" there was an altogether more direct message "This is the last time you can launch this app."
But it was once again not the truth. Lightroom continues to behave as it always did. The nag window appears, with the more benign message, I dismiss it, and continue using the Library module.
The funny thing is... I have actually been reconsidering a subscription anyway. Not being forced into it actually makes me slightly more amenable to paying them. If they'd shut me down, I'd not pay them out of spite.
06-11-2021, 03:01 PM   #17677
Transit's Avatar
Local photography legend Vonnie Cave has passed on.
Good taste in gear I see
Blowed if I can ID what model
Moto G (5S)  Photo
06-11-2021, 06:52 PM   #17678
zkarj's Avatar
QuoteOriginally posted by Transit Quote
I'm gonna say a K20D based on the knurled knob on the left and the sweeping lines on top. See here.
06-11-2021, 07:29 PM   #17679
Transit's Avatar
yes i think you're right
06-13-2021, 04:11 PM - 2 Likes   #17680
Transit's Avatar
I tried Picassa, might have cured my wish for big coloured buttons
seems it can't read PEF either which i seem to have a shed full.
Will keep watching darktable tutorials
06-15-2021, 08:24 PM - 1 Like   #17681
zkarj's Avatar
The power of Lightroom keywords...
I just added 495 keywords to 85 images in 10 minutes (actual measured time). These were the location (same for all), aircraft identity and type (13 different aircraft, some shots with more than one), and the operator for 11 of the aircraft. Two of the aircraft were new to me which required adding their identity under the correct type in the hierarchy. All keywords entered by typing directly in the keyword entry field, including the new ones, and the time included some basic research on a few of the aircraft to ensure I had the tags correct.
06-16-2021, 04:08 AM - 1 Like   #17682
QuoteOriginally posted by zkarj Quote
Having your images keyworded is handy too. I just found several instances of unauthorised commercial use of some of my images, and one of them I knew where it was taken, but wasn't sure when, as I had several of the same location taken some time apart but it didn't take long to locate it.
---------- Post added 06-16-21 at 11:37 PM ----------
I found out Local Government NZ is having their conference in Blenheim this year. Apparently they like my photos, but not enough to pay for them.
Getting there | LGNZ 2021
Here's where they got the image from.
Seven Scenic Marlborough Road Trips
They used my image to link to Destination Marlborough, the official tourism agency for the region, who received a $784K grant from the council last year for marketing, and actually have a huge free photo library they hired a social media influencer to provide, so it seems like some laziness or lack of communication between different organisations, as they should have been able to find a legitimate free image if they didn't want to pay.
Possibly my keywording and general SEO (Search Engine Optimisation for those who're not website geeks), might have worked better too.
It does look as though the event management has been outsourced to a project management company, who in turn seem to have outsourced the website to someone else, so at some point along the way, someone has cut corners.
I sent the organisers an email, so it will be interesting to see how they explain things.
06-16-2021, 05:25 PM   #17683
The LGNZ conference took down my image.
In some ways getting some money for it would have been nice, but at least they did the right thing.
06-16-2021, 05:33 PM   #17684
It's a sad state of affairs and all to common these days. If it's on the internet it must be free!
06-16-2021, 07:06 PM   #17685
My 9 year old was almost in tears as I explained how she couldn't just copy and paste stuff off the internet for a science fair project, and how you're supposed to cite work if you do use anyone else's material. She said all her classmates were just copying and pasting and the adult (not sure if she's even a teacher) wanted quantity rather than quality.
Apparently in under a term, the kids are meant to prepare a 50 page presentation as homework. Looking at some Masters theses I've seen, they're only twice that length, and get an entire year full time to prepare, preceded by another year full time getting ready to do the thesis.
I think a lot of teachers have no clue about copyright. I've found one of my images pop up on a school website before, and asked them nicely to credit it, but nothing happened.
I guess there's a young generation growing up thinking the way you earn from digital content is to become a social media influencer, complete with a fake life.
The trouble is there are digital tools that can easily detect plagiarism, just as there are to detect image copying, and just as it's easy to copy, it's increasingly easy to get caught.
aperture, bit, bobd, camera, display, ear, flickr, jun, k1, k5, kiwi, lens, lenses, new zealand, nz, pentax, pentaxians, photos, pig, pm, post, results, ross, saturation, sharpness, theatre, time, weeks, whanganui, yesterday
Kiwi Newbie :) Heidi Welcomes and Introductions 15 01-13-2011 09:04 PM
Another Kiwi has landed zk-cessnaguy Welcomes and Introductions 5 11-22-2010 05:00 AM
Another G'Day from an Oz Kiwi Tonto Welcomes and Introductions 4 04-26-2010 12:44 AM
Hi From yet another Kiwi Scott NZ Welcomes and Introductions 4 06-14-2009 07:24 PM
Kiwi sharp shooter (aspirations...) K-xx-500-user Welcomes and Introductions 11 10-07-2008 09:26 AM
All times are GMT -7. The time now is 03:46 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
