Originally posted by GUB I have tried to HDR the image but I am a beginner and the results are shite. Too little time to try and get the hang of HDR.
Rich-- you do some HDR -- I did a 3 image bracket with a 2 stop gap. Would that be ball park for this type of image?
I am having no luck with a sensible colour output with it-- mostly a totally different cast.
The program is Luminance HDR on linux.
Hi, assume Rich is me?
In that particular photo I think the power is in the soft feel of it overall. HDR is primarily to capture detail in areas that are wildly different in lighting levels, resulting in an exposure range greater than a camera sensor (but not the necessarily the human eye...) can distinguish. In your case, do you really want to expose the details in the mountain shadow for instance?
I suspect simply pulling down the highlights would be sufficient, or manually exposing a little 'darker' to start with, to protect all the highlights at point of capture. This may introduce some noise in the dark bits however...
Yes, the + and - 2 stops is a pretty standard approach, and the exact required settings are determined by your subject matter. If there is a massive discrepency between light and dark in the scene, then you may have to space these wider apart to capture sufficient detail in each area.
Not sure what the weather was like last night over your way, but it was stunning (though rather cold) in Palmerston North. I'm planning a night mission to capture the sky with the kit lens tonight, for use on a rainy day as a sky background if required. Maybe you could retake your shot with clearer skies to show the mountain more defined? By all means bracket away, if nothing else the middle one is likely to be useable right away, but you've got the option to HDR it at a later date also if you want.
HDR can easily be 'over baked', but fundamentally it's actually no different to using a graduated filter on the sky for instance... (just a gibe to agitate the purists there
Couldn't resist a play, no offence intended ...
Attachment 227362
