Have you seen my
Cactus RF60 flash and my
Cactus V6 radio trigger reviews?
These reviews do not only evaluate the gear but also provide some information about flash photography with Pentax gear.
Yes and there is a big price gap between P-TTL ("Pentax capable") and manual gear.
The current Pentax flash models are insanely expensive and you should only get them if you desperately need weather-resistance. Even then, you should ask yourself how many times you can actually make flash during rain look good and whether you don't want to protect your flashes in some other (cheap) ways.
Affordable P-TTL flashes are made by Metz, for instance. Unfortunately, in the past their flashes could not be used as an HSS-master (an on-camera flash that controls other flashes in HSS-mode). I don't know whether they have addressed this in the meantime.
Everything else being equal, I'd avoid Sigma, because their flashes tend to be slightly incompatible with third-party gear.
To P-TTL or not to P-TTL, this is the question.
P-TTL gives you the following:
- Automatic exposure control. The camera and flash work together to work out the appropriate power level for the flash.
- HSS. The camera will allow you to use sync-speeds above 1/180s.
- Second-curtain sync. The camera will trigger the flash shortly before closing the shutter (as opposed to shortly after opening it).
Regarding automatic exposure control: Many flash photographers use manual control even if their flashes support automatic exposure control because the results are more predictable and consistent.
If you are using P-TTL, any change in the scene may impact on the overall exposure, e.g., someone with a white shirt walking into the scene may cause other faces to become underexposed, etc. P-TTL has proven to be problematic with the K-5 (II) as it has an overexposure bug and while the K-3 fixed that, it introduced a shutter lag with P-TTL.
In the past, manual flash photographers had to pay the price of needing to walk up to their flashes every time they wanted to change power levels. With the advent of remote-controlled flashes like the YN560-III, V850, or RF60, manual flash photography has become hugely more convenient and much faster.
Another problem is that for P-TTL to work, the flash needs to be connected to the camera as there are no radio P-TTL triggers for Pentax. So you always have to carry both camera and flash around.
Furthermore, P-TTL is very outdated and cannot control multiple flashes well. There is a "contrast" mode that sets one flash to 1/3 of the overall power and another one to 2/3 of the overall power, but that's it. With manual control, you can set ratios of multiple flashes just as you need them.
Having said all that, if you are doing event photography with quickly changing scenes, P-TTL will probably come in handy because you may not be able to keep up changing your flash levels manually quickly enough.
Regarding HSS: With Pentax cameras currently the only way to use HSS is by using an HSS-capable flash connected to the camera. Once you have one of these, you can use a few selected flashes to fire them in HSS mode, i.e., it is not necessary to spend P-TTL money on all flashes involved. The Godox V850 and the Cactus RF60 support manual HSS. I described the
manual HSS concept for the RF60 and am not sure what limitations you may hit with the Godox V850. Bdery did a
homepage review for the V850, but IIRC he did not expand on the manual HSS feature.
BTW, the
Cactus V6 can also be used in a manual HSS setup.
Regarding second-curtain sync:
You need this to obtain motion trails that look right. My
explanation of the second-curtain sync emulation on the RF60 contains a sample image.
The manual emulation of second-curtain sync by using a manually set delay time (both RF60 and V6 support trigger delays) is cumbersome and unless you plan ahead, will take quite some time to figure out on the spot.
See above for how V6 and RF60 support HSS, but as I said currently the only way to get a trigger signal from the camera once the shutter speed is beyond 1/180s is to use an HSS-capable flash connected to the camera. So you'd need at least one of these (does not need to be HSS-master capable).
ND filters are an alternative to achieving the same effect, but you may have to use multiple flashes to compensate for the light loss. Make no mistake, though, HSS also requires more flash power than usual. A flash's HSS output is equivalent to (brief) constant lighting and shutter speeds beyond 1/180s will diminish the contribution this light can make to the exposure. At 1/8000, you are getting 5 1/2 stops less output from your flash compared to 1/180s. So ND filters are not the only flash power suckers.
Have a look at my
flash comparison, it may help you to come to a decision.
Although the Yongnuo prices are tempting, I would avoid their products. It is a very closed system with unnecessary incompatibilities within their own product range. Although their reliability has apparently become better over time, I'm convinced you'll have a better experience with slightly more upmarket gear (both in terms of failure rate and in case something goes wrong).
I personally think the Cactus gear is really nice (if you don't need/want P-TTL). Cactus thinks backward compatibility is important so your gear will most likely play with future gear. They have considerably expanded their
dealer network (in addition to
selling online) and I've heard that in Canada you get three years of warranty on Cactus gear.
Let me know if you have any further questions.
If you plan a trip to Wellington, let me know, and you can play with the Cactus gear I have.
