I think these discussions are worth consideration. If you buy a DSLR with interchangeable lenses, but stick with the stock budget lenses, then you may well have been better off with an all in one, with a better quality/matched fixed lens.
As 'basic' camera specs improve, the need for a DSLR specifically moves wider out into the fringes. You'll benefit for low light performance, (try using a cellphone in anything other than medium to bright lighting levels), more control over depth of field etc, but on a good bright overcast day a quality bridge camera may give you better quality all in focus images. Adding good quality big zooms to DSLR's is expensive, often costing more for the lens than a bridge camera itself. Going to FF with the larger image circle ups this again.
If you're like me, with limited funds at the moment, you start to question if I'm in the right game and getting the best images I can for the money I have to play with.
It's hard to find a bad camera these days.
I prefer an optical viewfinder, so aren't going anywhere soon. That said I'd like an EVF too, so I could maintain the stable stance of stills when shooting video too.
