Originally posted by following.eric
Sorry if this is lengthy. I don't go out often as it's harder since it's late, but I have enjoyed it when it's gone well. I enjoy seeing something I can't quite see with my eyes but my camera shows me the hidden beauty.
Thanks. Useful info in there. I tried some astrophotography with my K-50 last year, but wasn't getting the results I wanted. ISO 1600 seems to be about the limit for noise, at least with what I was trying to do. You made a good suggestion to use higher ISO and then drop down once you've checked composition.
I'm thinking the KP might be a worthy successor to my K-50 when I can afford it. I had thought I'd need a long wait to save for the K-1, but looking at reviews, I probably can get 2 stops higher ISO with similar noise to K-50 at ISO 1600, which would put me in reach of what I've been attempting.
As a side note, I found once you push the ISO up to 1600 or higher, a flash can work quite well at illuminating hillsides even 100m away, (possibly with multiple manual triggers off camera while the shutter is open). The only thing is white balance is totally messed up, and I ended up having to use the adjustment brush in Lightrom to apply selective white balance to the sky and the foreground as they were different.
Here's one of my efforts, at ISO 3200 50mm F1.4 8.0s. It's a bit too noisy for my liking but longer, and I was tending to get star trails. I'm pretty sure I used off-camera flash, as I didn't want just a silhouette of the hills. I found moonlight gave too much light pollution so the stars didn't really show.
---------- Post added 03-30-17 at 01:27 PM ----------
Originally posted by awa355 The maximum shutter speed on the K50 is 1/6000. For what, and when would you set the shutter speed to this rate?. Also if for example, you are using 1/6000, what would your other settings be?. I'm picturing dragon flies hovering maybe?
There are two scenarios I can think of.
A long telephoto to freeze action. The rough rule of thumb I've heard is 1/focal length to freeze avoid camera shake, however with Pentax shake reduction, you can probably go a bit slower.
The longest lens I've got goes to 300mm, so theoretically 1/300s is minimum I should be looking at, but if I'm trying to capture a fast moving subject, say a bird in flight, I'd need a considerably higher shutter speed, although 1/6000 is pretty high. At that sort of speed you're going to need a high ISO, and that's probably going to be a limiting factor.
With the K-50 I'm happy up to ISO 1600, and in good lighting maybe occasionally ISO 3200 if I'm really prepared to push it.
The other scenario is a fast prime. My FA 50mm 1.4 is so fast wide open, that in broad daylight, even 1/6000s at ISO 100 is sometimes barely fast enough to prevent over-exposure. It's not often that I'd actually want to shoot with those settings, but having a high shutter speed at least means it's possible.
This kind of scenario could crop up with any fast, relatively short focal length lens.
