Originally posted by richandfleur Trying to work out why these would be the way to go over say a basic trigger, like the cowboy NPT-04 units.
There is a huge difference between a simple trigger and an advanced one from Yongnuou, Godox, Cactus, etc.
An advanced trigger let's you manage multiple flashes individually (-> group management). You can de-/activate them remotely as you need for dynamic situations, or just to work out the overall setup by evaluating each flash's (group's) individual contribution.
An advanced trigger also let's you change the power level and the zoom level (for each group individually) from the camera position. This is an awesome feature you'll never want to miss once you have used it. For some situations where flashes are in hard to reach places (e.g., high up on a stand, in a closed softbox, 20m away requiring climbing to access, ...) this feature can be rather essential (going beyond convenience).
Depending on the actual trigger, you'll get further goodies such as being able to cycle through multiple flashes for superfast (virtual) recycling, creating masks, creating stroboscopic multi-exposure images with spatially distributed flashes. Have a look at the
Cactus V6II manual to see all the additional goodies such as delays, remote camera triggering, absolute power mode, etc.
The V6II already supports HSS for Pentax. The V6II and the Acon R930 are the only ones to do so in a convenient fashion.
Another advantage of the Cactus system is that it supports multiple brands. Not only can you use one and the same hardware for other camera systems, you can also mix and match hardware in a single system rather flexibly. Triggers from Yongnuo or Godox only support their specific product range.
Originally posted by sqrrl If I was going to go really cheap I'd probably go for the Yongnuo RF-603
That's a basic trigger and can be fine, if you don't want anything more than simple triggering of flashes.
Make sure, though, you are avoiding brand incompatibilities. There are Yongnuo triggers that only work up to 1/160s on Pentax cameras and require tricks/modifications to actually reach 1/180s (or even 1/200s).
Originally posted by sqrrl If I was going to spend more then i'd go straight to pocket wizards or something specific to the brand of strobe (ie elinchrome triggers for elinchrome).
I don't see how pocket wizards would be advantageous over the V6II. They don't support HSS for Pentax to start with and also lack many of the other V6II features.
When alternative radio triggers where still unreliable, pocket wizard triggers were the top of the class, but nowadays, they don't have a lot going form them, in particular not for Pentax shooters (their TTL support is for Canon/ Nikon only).
Originally posted by sqrrl Shooting with pentax you're pretty well stuck with manual mode shooting (ie - no ttl), so there's not much point in paying for the feature unless you use multiple systems.
As Mark wrote, Cactus will release a Pentax P-TTL-capable firmware for the V6II as a free update. This firmware will allow you to use automatic metering and even mix automatic metering with manual control.
Did I miss any questions? If so, just shoot (no pun intended).
