Originally posted by awa355 For photographing cycling what focus settings would you use?
I started with 5 point for the side on photos then decided the camera was focusing on the hedge behind the riders. Went to single point then. For the more front on pics, I think I was using the 5 points option again.
I wish the exif info showed what focus setting was used. I see that the focus range in the EXIF info state 'Distant' Can anyone explain this?. Thanks. All these are cropped jpegs.
I've never photo'd cycling.
For side on I'd try panning at least a little to show wheel spinning, so I'd start somewhere around 1/100th and see what develops (pun intended). If that works try slower. Naturally you'll end up with a smaller aperture, but that doesn't matter as the background would be blurred by the panning hopefully. The more you practice the better at it you'll get.
For front on I would try and isolate a cyclist using f2.8, shutter maybe not below 1/1000? Again, trial and error. If you want a group to be in focus naturally a smaller aperture which you may have to make up for by a higher ISO or slower shutter.
For all these I'd be TAv mode.
You'll just have to experiment to see what results you like.
