Originally posted by awa355 A question, if photographing people in a large well lite function centre as I will on Saturday, what camera settings would suit?. Av, wide aperture (which seems to pick a slow shutter speed) or Tv, a slowish shutter speed?. . The camera is my K50 and I will only have the DA 18-50 lens. No sense taking a zoom lens.
My thoughts here would be to lock down how the camera meters the scene (I most often use centre weighted) to ensure you get the subject exposed correctly.
Examples of issues can be where someone walks in front of a bright window, and the camera meters for the bright parts, ensuring you can see what's outside the window, but your subjects are now really dark.
Watch for minimum shutter speeds, which cause blur if they dip too low.
If you can get the metering working well, then I'd probably pick Av mode myself, or stepping up to TAv if the camera is calculating too slow a shutter speed, so I could lock that at a suitably fast (but not too silly) speed.
On all my Pentax cameras, I lock the ISO at a max of 3200, or dropping to 1600 if light conditions allow. The noise is just too much after that, in my opinion.
Moving to the K-3 unlocked all the controls over the auto modes, which weren't there in the K-30, giving you the ability to tell it what to prioritise in it's auto calculations.
Other option is to use a Prime lens, so you can let in more light than the kit lens by selecting an aperture like f2.4 on the 35mm of f1.8 on the 50mm for example.
Narrows the depth of field though, so watch the focussing is bang on.
I tend to use single centre point focusing for this type of work, assuming you're not trying to track people walking towards you or away from you.
Sorry, lots of content there, and I hope some of it is useful?
All the best.
