As many have said above, resist the temptation to change lenses in the field. Pick a lens and camera combo, stick with it until you get inside a tent, building, or a vehicle, any place you can close the door and wait for the dust to settle before changing lenses. Consider a carrying second body and lens if you plan on switching between a zoom and a prime. If you plan your day, though, you can guess what type of lens you need. I think your 24-70WR would be the best choice. From my own travels there, I used the wide end of a zoom far more than I zoomed.
FWIW, I travelled and hiked though Arizona with a K-1 and and a non-WR lens, the FA 24-90 IF AL. No issues in daily use, but I recommend a CPL, it not only protects the lens, but it cuts the glare in the same way sunglasses do for your own eyes. Also consider an ND filter, because the light can be so intense that even the lowest ISO will still push to the highest shutter speeds, and ruin the contrasts.
The Arizona desert conditions are different from the deserts of the Arabian peninsula, the sand is a fine grit that gets into everything and fine particles get carried by the slightest breeze, which is why I recommend NOT changing lenses in the field. I travelled through Iraq and Kuwait using a K-5 and an 18-135 WR almost exclusively. Again, I had a CPL on, better than a UV for the same reasons I mentioned above.
I also recommend a a soft brush and blower bulb to clean with.
Unlike what Hollywood shows in films, sandstorms do not scour the pain off cars, not flesh from bones. If you were out in a sandstorm, you would want some good sunglasses that fit closely to protect you eyes, I have some Wiley-X sunglasses with a gasket around the eyepieces, more comfortable than goggles. You would also want some type of scarf or mask to cover your mouth in a sandstorm. When I was in the UAE, some of the locals showed me useful a head covering , Kaffiyah is for the desert.
The dust/sandstorms won't affect your car over a month, and if they did get that strong, you'd have bigger problems than chipped paint, best thing to do is wash and wax (preferrably by hand with something like Turtle Wax) for protection before parking.
Don't leave anything electronic in direct sunlight, though, I lost a point and shoot camera that way.
