Originally posted by bymy141 Hi,
I guess I'd like to get as close to:
- 400mm
- with reasonable lens speed (min f4 ??)
- as light as possible
- minimizing lens changes
- perferably sealed
- HSM would be nice....
Do you agree?
- Bert
Bert.
in looking at your list, you have a lot of points that are mutually exclusive
- 400mm @F4 and as light as possible.
Someone else already pointed out that this lens will be a beast with a front element of 100mm minimum. Realsitically this lens will have a 112mm (somewhat standard) front filter diameter. it will not be light. There is a tamron 400mm F4 in the database at 2270
This is 5 pounds
- minimize changing lenses vs as light as possible
this implies a zoom zooms are muchg heavier, the only one I found in the database at this focal length are the F 250-600 F5.6 (same 112mm filter) at 4900 grams
(over 10 pounds)
The bottom line is you are not going to get F4 at 400mm with any reasonable weight, period, and then there will be the price
What that leaves you with is a choice of zooms but slower, with 77 or 86 mm front elements.
How you achieve 400+ will be your option of bigma all by itself, or shorter zooms with a TC or two,
I wouold put sealed at the bottom of the list. it is not really necessary, same goes with HSM.
