Originally posted by ghelary
Ok, lets explain my point of view. If we ever make a front filter for this lens, the surface of it would be around 5 times bigger than of a 77mm filter.
A filter is made of ultrathin plastic or glass to avoid things like adding chromatic aberations or influenting the optical patch. At such a size, it would be exotic to produce perfectly flat surface, but the mechanical contraints on it (mount, gravity) would also make it tricky to keep it flat while mounted on the lens (even glass can be deformed at some point)
Therefore a "wise" technical solution would be to use thicker glass, potentially introducing chromatic aberations.
We all know about the problems filters introduce. What you wrote now is exactly why I answered in my first post in this thread, that I would not recommend using a filter.
Also, quite as you wrote, producing an optical flat is basically the most complicated thing to do - agreed on that, but ofcourse you can get optical flats up to a considerable higher diameter, if money is of no importance
But I was not questioning these things, I was just questioning, what you wrote about front filters being a part of the optical design of a lens. That is not necessary and is not common at all for standard photographic lenses.
And we not mentionning also the added potential for flare, as the coating on the front element of the lens was likely not optimised to reduce reflections (nothing was supposed to be put on front of it)
The coating on that lens is the same SMC, that is used on all lenses of that generation. And ofcourse SMC was/is Pentax highly successful) mc to reduce reflections. I mean, after all, reducing reflections is the exact purpose of multi-coatings by any vendor. Why that would work less effectively than on smaller lenses, I do not really understand.
Nevertheless I agree, that not using a filter in front of that lens is the best way to go.
Ben
