The DSLR won't work with my flashes, I think, the AF400T and one that's on its way, the AF500, although I admit I haven't tried. One of the pictures I need this for would be fill-in flash outside, so I do not need TTL for that, but at least one other is going to be inside, with bouncing of the walls and ceiling. I want the 400 to work its TTL and the other to work as a slave. I'm not sure how to pull this off on the DSLR (K-x) unless I were to use triggers but I've never used anything like that (in general I'm pretty new to flash)
But you are right that it would be much cheaper, probably faster, and more future-proof. Guess I have to work this one out!
