Originally posted by tuco First off, what Sekonic flash meter do you have? Mine you can connect the flash cord directly to the meter and fire the flash or set the meter to read when the flash goes off and then trigger the flash manually with the button on the flash unit. My meter has an attachment for the flash - a flat white-defused cap and a spherical cap for measuring ambient light.
You can do a double exposure with the 90mm LS but not the 165mm LS as a lens feature. Plus you can do pure leaf shutter exposure with the 90mm LS to eliminate the mirror if you want. You can find the instructions in the 90mm LS manual that can be found online or I can post it for you if you like.
The 67NII has double exposure capability, so I've read (I only have a 67). Doesn't the manual for the camera tell you how to do that?
Thanks. I have both the Sekonic l-758d and gossen digiflash.
I continue my test and found out that my SB-800 flash test button is inoperative. I may have to use my SB-600 for that purpose. That might resolve the issue.
For the double exposure, I have read the manual and test (or waste) a few film. It is still not clear.
May be I should continue my test.
