Help! Well an old habit may have just broken my new mint 645n I just got, I went to turn the shutter speed dial and lifted up to turn instead of depressing the center button on the speed dial and the dial and center button came right off into my hand. Nothing appears to be broken or missing, i can put the center button back in place and depress it and the speed dial turns without the actual indictor knob in place, Problem is how does the knob stay snapped down . like I mentioned i had turned the knob without problem and after reading the manual when i recieved thecamera, just had a Nikon brain fart and lifted this time and off came the works. Nothing looks broken, being all plastic that is usually easy to spot. Does the knob just snap back on, i don't want to force it. It sure didn't take much to have the 2 parts jump off the camera!
Rory
Well upon closer inspection and better light with a magnifier it looks like the 3 posts inside the speed knob that attach it to the actual turning assembly while depressing the release button in the center all "sheared" flush or became "unglued" so I couldn't feel them and the left no debri inside the speed indicator knob. Glue failure from age? Camera is flawless and shows no signs of wear or abuse. I'm shocked, either were partially broken and I caused the final failure or that knob is very fragile because I pulled up but it wasn't like I stood on the thing and yanked!
Any ideas? someone know where I can get it repaired. This is a major bummer!
paperclip in attached photo points to 1 of the 3 posts that appear to have broken !
Reason: sad news
