07-22-2010, 09:42 PM   #1
RawheaD's Avatar
67II Frame Spacing Issue
Hi,
Just got a 67II which was supposed to replace my 6x7 MLU (currently in the market place), but after I shot through my first test roll, I quickly saw there was a problem.
As you can see (sorry for the bad iPhone pic), the frame spacing continues to get wider and wider as if the camera is ignoring what frame it's shooting. I've heard dead batteries can cause a similar issue, but the battery is alive and well and counted up to 10 frames without a problem. Yet, I only got 8 and 1/3 frames in this 120 roll.
Sooo, I'm thinking this'll probably have to go to Colorado to have it fixed... the question is, has anybody gotten anything like this repaired on the 67II?? How much do you think I'm looking at?
Thanks for any help..
07-22-2010, 10:39 PM   #2
Wheatfield's Avatar
This is a very common problem with the 6x7s, though usually it is overlapping or small frame spacing that is the issue.
It shouldn't be a hugely expensive repair, since it is actually a very simple and minor adjustment of the advance clutch.
07-22-2010, 11:45 PM   #3
RawheaD's Avatar
Thanks for the input; however, do you think this is the same issue?
This isn't "erratic" frame spacing. The spacing gets larger and larger towards the end, which suggests to me that the camera/winder isn't compensating for the take up spool getting thicker and thicker. From what I gather, the film counter should be communicating to the windeup mechanism just how much it should turn for each frame, depending on (a) the type of film that is being used (120 vs. 220), and (b) what frame you are currently on.
The frame counter itself is working perfectly; which means there's some kind of communication error. I don't think it's a matter of slightly adjusting something (to make overlapping frames go away or shorten the spacing when its too wide), but rather something more electronic, between the frame counter and the winder.
07-23-2010, 09:34 AM   #4
Wheatfield's Avatar
Anything that isn't as it should be is erratic. In your camera, the clutch appears to be too tight.
I'd be very surprised if it is an electronic problem.
07-23-2010, 11:02 AM   #5
troyz's Avatar
Is there a slip clutch for the takeup spool of a 67II?
I've seen the faulty-takeup-spool-clutch-causes-erratic-frame-spacing problem on the older 67, but my impression is that the film transport on the 67II works quite differently, using an electronic rotary encoder to measure film travel and some other electromechanical bits to stop the film transport once the film has traveled the distance of one frame.
At least this is what I recall from my discussions with the local repair guy.
07-23-2010, 11:44 AM   #6
Wheatfield's Avatar
If that's the case, then it would definitely be a trip to the repair shop. I figured that they probably hadn't done much with the film transport other than put a motor onto it.
07-23-2010, 12:32 PM   #7
GeneV's Avatar
FWIW, and it isn't much, I've found 6x7 backs for the RB67 also to be somewhat erratic in that the frame spacing is not nearly as consistent as in 135 or 645. It is an annoyance in cutting the strips for scanning or once in a while, I'm cheated out of a frame; however, if the frames are overlapping, then there is a real problem that needs to be fixed.
07-24-2010, 10:56 PM   #8
RawheaD's Avatar
Thanks guys for all your input. To the repair shop it went. To my surprise, it wasn't Colorado but Arizona (when did that happen?). Fortunately, the seller agreed to foot the bill for the repair. Still, it would be nice if it didn't cost a fortune.
12-04-2010, 04:24 PM   #9
RawheaD's Avatar
Just to follow up; the cam came back from Arizona, the repair/CLA cost $200, and now it's like new. I love this camera! :-D
05-01-2011, 05:12 AM   #10
And? What was the problem then?
Very curious to know.
Anton
05-05-2011, 10:43 PM - 1 Like   #11
RawheaD's Avatar
QuoteOriginally posted by antonroland Quote
Anton
It was the winder. Didn't say anything specific.
67ii, camera, frame, frames, issue, medium format, roll
Contest Poll Contest #41 Voting (Frame Within a Frame) Damn Brit Monthly Photo Contests 31 02-19-2010 05:49 AM
Spacing out my fast lens setup dugrant153 Pentax SLR Lens Discussion 16 01-25-2010 08:38 PM
Expired Theme Theme: Contest #41, January, 2010 (Frame within a Frame) Adam Monthly Photo Contests 11 01-21-2010 12:33 AM
Jan 2010 - Frame within a Frame MattBrennan Monthly Photo Contests 0 01-17-2010 06:30 PM
Contest #29, January, 2009 (Frame within a Frame) Joshua Hakin Monthly Photo Contests 0 01-07-2009 09:39 AM
All times are GMT -7. The time now is 11:30 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
