08-16-2010, 08:53 AM   #1
Dubesor's Avatar
67 to 645
I am looking at getting a 45mm P67 lens. What sort of field of view would that offer on my P645 (compared to a 35mm film lens or APS-C)? I already have the necessary adapter.
08-16-2010, 12:15 PM   #2
To determine the 35mm equivalent, multiply by .6. In this case the 45/4 would equal a 27mm lens on a 35mm camera.
08-16-2010, 01:35 PM   #3
The 45mm used on the 645 would have a 76 degree field of view.
08-16-2010, 02:30 PM   #4
Dubesor's Avatar
So the FOV will be quite a bit wider than the 645 system 55mm focal length lens I used to have (54 degrees horizontal FOV) ... that's good news.
08-17-2010, 01:03 PM   #5
The 76 degrees I quoted is across the diagonal. Nearly all lens field of view is quoted that way. Your 55mm should be 65 degrees across the diagonal.
camera, lens, medium format
Pentax Medium Format Resources: 645 & 6x7 Cameras and Lenses, 645 & 6x7 Accessories Adam Pentax Medium Format 9 02-12-2017 03:38 AM
help with a 645 Prox-iee Pentax Medium Format 2 01-13-2010 07:37 AM
All times are GMT -7. The time now is 03:51 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
