10-17-2010, 06:00 PM   #16
Steve,
I'm curious as to why you think the M* 800 uses a Flourite element or two. I know that early on Minolta experimented with Flourite, but went to anomalous dispersion glass in their big tele's. I thought Canon was the only manufacturer to use it regularly. Does Pentax have a history of using Flourite?
Scott
10-18-2010, 02:28 PM   #17
Scott, there have been several lens producers that have used Fluorite elements. The 250mm Superachromatic lens from Zeiss used Fluorite as well.
There is no history of Pentax ever using Fluorite. Pentax has been fairly secretive about their lenses in general but the following is why I suspect the use of Fluorite in the 800 f/6.7. It is rare to see a negative element being low dispersion; nearly all are positive. The low dispersion element in the front group of the 800 is very likely positive. The fact that the positive element is surrounded by two negative elements, looks as though they are trying to protect it from the weather. Fluorite weathers easily. Using a Fluorite element as a front element is not done. It is possible that the positive ED element is some other type of Fluoride ( not Calcium Fluoride ). I'm betting on crystalline Calcium Fluoride though , AKA Fluorite.
10-20-2010, 06:34 PM   #18
Pentax made a Takumar Ultra-Achromatic (Apochromat) using Calcium Flourite materials.
Ultra-Achromatic-Takumar 85mm F4.5 Lens Reviews - Pentax Lens Review Database
Ultra-Achromatic-Takumar 300mm F5.6 Lens Reviews - Pentax Lens Review Database
1973 prices were $1,400 for the 85mm and $1,600 for the 300mm.
The sought after SMC Takumar 85mm f/1.8 was only $259.50
A complete Pentax 6x7 with pentaprism and 105 f/2.4 was only $1,049.00
Where is that time machine?
10-21-2010, 03:04 PM   #19
Thanks Nightfly, I had never seen that. The description says quartz fluorite. I think they meant that one element was Fluorite and another was quartz.
The fact that two earlier lenses used Fluorite makes the odds of the 800ED using it more likely.
10-21-2010, 04:06 PM   #20
QuoteOriginally posted by nightfly Quote
You don't have to go back to the future that far. When I purchased my 6x7 (some 20 years ago), you could pick up a gray market system for about that price.
10-21-2010, 04:30 PM   #21
QuoteOriginally posted by desertscape Quote
Growing Calcium Flourite into large enough crystals for large elements is an expensive process. That might be one reason for using them in a slow lens design. They would seldom be used for front elements as they can deteriorate easily.
Modern ED glass is very good and lessens the need for flourite in the design, but flourite can correctly focus light beyond the violet and ultra-violet range. It is commonly used in expensive astronomical refractor telescopes. Again, expensive!
11-24-2010, 11:47 PM   #22
Takumar 85mm 4.5
The Patent paperwork on the 85mm lens says that the two positive lens elements are fluorite and the negative elements are quartz (I think it says "fused silica"). I don't think that lenses newer than these used fluorite elements. The Pentax tech people that I talked to in the late 70's, 80's and 90's said that ED glass was preferred because of better durability. Anyway the the 85 is cool because it has no glass in it.
6x7 lens, camera, lenses, medium format, version
Applying Lens corrections using Pentax Digital Camera Utility 4? HGMonaro Digital Processing, Software, and Printing 3 09-07-2010 05:56 AM
News Reputation now awarded for lens & accessory additions Adam Site Suggestions and Help 0 06-29-2010 04:59 AM
Confused about lens corrections in DNG Clarkey Digital Processing, Software, and Printing 8 03-12-2010 10:11 PM
Pentax Digital Camera Utility 4, K7 and Lens corrections problem Labuzan Digital Processing, Software, and Printing 2 12-28-2009 10:09 AM
For Sale - Sold: [SOLD]Next lot from the 300+ lens sale. New additions. benjamin59 Sold Items 63 02-17-2009 01:31 AM
All times are GMT -7. The time now is 10:54 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
