11-15-2010, 07:22 PM   #1
67 shutter lock for long exposures?
I'm doing some astro photography tonight. Since I can only get one shot per night, I'm a bit miffed that I'm not "recording" anything right now! The first shot, stupid me, I forgot to move the speed from 250 to B. My fault. The second shot, I put it on B, pressed the shutter release and then attempted to move the shutter lock to "L" as I would on my MX. No dice, it does not move while the shutter button is depressed. Is there any way to lock the shutter open other than using a cable release? Should I resort to zip ties to actuate the shutter tonight?
11-15-2010, 10:00 PM   #2
Wheatfield's Avatar
Cable release.
11-15-2010, 10:04 PM   #3
The manual (on p30) seems to suggest the need for a cable release fitted with a lock.
11-16-2010, 12:54 AM   #4
ghelary's Avatar
Please note that the Pentax 6x7 (and I think it holds true for the later model models) will use up batteries for the time the shutter is opened. I learned it the hard way (one exposure through the night, no more batteries in the morning, it was a new one)
There are 67 specialy modified for Astrophotography that have been made. I suggest you google it if you are really into that.
11-16-2010, 05:10 AM   #5
Thanks for the help guys! I'll go get a cable release today. I went ahead and took a shot with the MX instead. I'm aware of the battery limitations, at this point I don't plan on doing this enough to worry about it, but depending on how I like it I may have to do the mod.
11-16-2010, 06:23 AM   #6
Andres's Avatar
There's a way to lock the long exposures...
You have to put the speed dial in the area between the 1000 and the X there, when you push the shutter release it'll get locked...
I'll quote the 6x7 manual page 11
Time Exposure
By setting the shutter speed dial anywhere in the space
between X and 1/1000 sec., you can take Time
exposures. To close the shutter, turn the speed
dial to X or 1/1000.
Double exposures cannot be made with this camera
11-16-2010, 06:52 AM   #7
QuoteOriginally posted by Andres Quote
Yes, I've used that mode when I left my cable release at home. Double exposures can be done with the 90mm LS lens and this mode.
11-16-2010, 03:32 PM   #8
Awesome! I'll give that a try tonight. Thanks
11-17-2010, 08:05 AM   #9
Rense's Avatar
This is becoming a 'tips and tricks' topic....
11-23-2010, 11:16 PM   #10
Isis's Avatar
Does this method still consume battery power like using the cable release?
Cheers
Shane
12-02-2010, 07:28 AM   #11
Andres's Avatar
QuoteOriginally posted by Isis Quote
Cheers
Shane
Good question... but I have no idea :P
Great Tip! I wish I had a LS lens LOL
12-02-2010, 04:59 PM   #12
Cheers
Shane
Mirror up consumes battery, so it probably does.
The fact that Pentax offered a modification for astronomers that prevented battery drain during mirror up use would seem to confirm this view.
12-02-2010, 05:19 PM   #13
Wheatfield's Avatar
Everything a stock 6x7 does consumes battery power. I recall the manual states that a fresh PX-28 (silver-oxide) is good for about 6 hours of total exposure time.
Mirror up consumes battery, though I don't know how much compared to the shutter.
12-02-2010, 05:42 PM   #14
The above method does use battery power. Here's a technique I used years ago before I had a 67II. (lited from a p-net thread)
"I did a search for long exposure techniques with the 67; none I found was really straightforward. The following procedure worked for a 3 hour exposure using a Pentax 67 without exhausting the battery: 1. Focus a tripod-mounted 67 and advance the film and lock up the mirror. 2. Remove the battery. 3. Have the shutter speed set a "B" and depress the shutter.
The shutter will not close until the battery is returned. Most tripods will will require removing the camera from the tripod and QR plate to remove the battery and since the mirror is up, the compostion can't be checked upon remounting the camera. Not really a problem for wide angle shots, but could be with long lenses."
NB If I remember correctly this works with the shutter set between any 2 speeds, e.g. 100 and X.
Good luck
12-02-2010, 07:30 PM   #15
QuoteOriginally posted by Thomas Quote
Good luck
I believe this technique works for the 6x7 model. I tried it with a 67 and pulling the battery out closes the shutter and drops the mirror.
I made a device for use in astrophotography. It simply holds the safety button ( the recessed button below the shutter release) in while the extended exposure is made. Once this button is held in, you cock the shutter, operate the mirror up if desired first, then press the shutter release to open for the exposure. It does not matter what shutter speed you have selected and you should not have a battery in the camera for this to work.
The link below shows how I made a simple plate that temporarily attaches to the camera for this operation. I used a cable release to operate the safety switch and releasing the cable release to end the exposure.
A company named Hutech made one for years, but no longer makes them.
I've shot hundreds of hours with this setup and no battery!
http://www.cloudynights.com/ubbarchive/showflat.php?Cat=&Board=Film&Number=1...v=#Post1702165
camera, medium format, move, release, shot, shutter
The K7 and long exposures pentaxmz Pentax DSLR Discussion 154 07-14-2010 06:53 PM
Cityscape Long Exposures attack11 Post Your Photos! 6 01-20-2010 01:49 PM
K20d - long exposures Luke_ Pentax DSLR Discussion 5 07-28-2009 05:30 AM
Long exposures. blwnhr Post Your Photos! 12 08-05-2008 03:36 AM
Pentax and long exposures ftpaddict Pentax DSLR Discussion 10 06-27-2008 11:27 PM
All times are GMT -7. The time now is 04:13 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
